Anyone who can support with some advice/direction, I will very much appreciate it!
Here are the facts:
- Both SE30s have professionally recapped logic and analog boards. Only the power supply has not been recapped.
- The same problem existed for each of these before and after the recaps.
- When swapping out the logic board between SE30s, the image follows the logic board. For this reason, I have uploaded two pictures of the SE30 screens, labeled Logic Board A and Logic Board B. These labels are based on the assumption that the problem must be with the logic boards in both cases, since the image follows each logic board when installed in different SE30s.
- Logic Board A has the horizontal lines.
- Logic Board B has the vertical lines.
- With 2 SE30s, it may be easier to diagnose/fix the issue. If absolutely necessary, I will extract parts from one in order to at least have one operational SE30.
- I have electronics repair tools: an old oscilloscope, soldering equipment, vmeter, etc. I have only a beginners knowledge of electronics (1yr hobbyist raspberry pi/arduino/various sensors/garage experiments), but I have a lifelong love for classic Macs!
- The world wide web.
- Hopefully you have some hints based on experience. I have lost the first battle. Any advice on how one might win the war?
