A few years older and possibly somewhat wiser, I've decided to revisit this project – especially in light of the recent progress with new hybrids and display cables being made.
As a quick rundown, the machine had been recapped already, so I left the caps alone. I've recently tried firing it up by connecting a bench power supply to the battery terminals (being careful to connect both positive leads and a negative lead), but I got absolutely nothing out of it. I then measured voltage on the +5V rail on Q16 and it measured 6.6V – the same amount I was supplying – so it seems the hybrid is feeding the battery voltage straight into the +5V rail. Not good.
I decided to check the hybrid situation, comparing my measurements to Androda's. Most of the measurements checked out, but there were a few notable exceptions:
- Pin 16 of the hybrid to Q1’s pin 2 showed high impedance, instead of the expected 4.4k ohms
- Pin 17 of the hybrid to Q1’s pin 3 showed high impedance, instead of the expected 9.6 ohms
- Pin 51 of the hybrid is disconnected from the positive side of C26, but is connected to R160
Digging deeper with the help of the schematics, I found out that there's no connection from R159 to C17 and R159 to Q1 pin 2, but there is continuity between C17 and Q1 pin 2 – suggesting an issue between R159 and C17. There's also continuity between R23 and Q1 pin 3, but no continuity between Pin 17 of the hybrid and R22. Finally, R22 and R23 themselves show high impedance when trying to measure their resistance.
All of this is suggesting problems with the power regulation circuit. I suspect that not only the hybrid might have gone bad, but the original caps around it might have corroded the board to the point of causing damage to R22 and R23 and severing a couple of traces.
With this in mind, I decided to test the rest of the board by supplying +5V directly to Q16, Q15 and Q20. When pressing the reset and interrupt buttons, this caused the machine to emit some garbled creaking noise from the speaker most of the times, but it did not want to go further – and it also pulled very little power (0.08A). Considering the issue with the +5V rail being fed battery voltage I had discovered earlier, I revisited TechKnight's suggestion that the SWIM chip might have gone bad, so I desoldered it and tried again.
With the SWIM chip removed, I can get the machine to make a happy chime
most of the times. However, it seems like the machine powers itself off after 2-3 seconds, as the current goes down from 0.4A to 0.08A. Occasionally, the machine will boot with a sad mac chime instead – and interestingly, in this case it will not shut itself off, and it'll keep pulling 0.4A. In this second case, the display – with the reconstructed ribbon cable – becomes solid black.
I think this suggests the main logic should be somewhat functional, but I'd need help to investigate the problem further. I do have a donor PB 145 from which I could likely transplant the SWIM chip, but before I do that, I'd like to make sure nothing else is wrong with the machine, and also sort out the broken traces situation with the hybrid.
After all these years, I hope I'll be able to bring this machine back from the dead at last, and I'm happy to take any suggestions you may have. Thanks!
