Jump to content
New CPU Accelerator options for 68K Macs?
Recommended Posts
  • 68kMLA Supporter
2 hours ago, mg.man said:
Are you sure?  The oscillator is 20Mhz
The oscillator is only connected to the FPU. The CPU is hardwired for 16MHz.
that memory expansion does look like a later one... v1.2... How many flavors of these did they actually make?
According to a product catalog from back then which I saw somewhere on archive.org the Mercury never did more than 4MB.
While we're at it: Total Systems Mercury.zip
Totally not tested and schematics have not been cleaned up for readability. Most parts values missing, you'll have to source those from the pictures.
GAL files are however correct and tested.
Link to post
Share on other sites
  • Replies 90
  • Created
  • Last Reply
Top Posters In This Topic
Good to know...
Speaking of while we're at it... I recently acquired a Gemini 030 in a sad state... it's configured for an SE, but it doesn't appear to be working... all I get when powering up is this... no "bong", no pointer... :-(
I suspect it's because one of the GAL? chips is missing [U4, upper left] (but really have no idea)...
Open to any suggestions or happy to send to you if you want / have time to take a look... Does the file you attached include GAL details for the Gemini?
Link to post
  • 68kMLA Supporter
Nope, those files won't help you there.
If the GAL in that open spot is indeed needed I'd say there's not much I can do for you without another one of those which has the needed GAL in place to make a copy.
Seeing you've got the power connector on there though makes me wonder if you need a secondary power supply hooked up to get it to work at all.
Can you meter out if the VCC pins on the PDS connector are even connected to any components on the accelerator? On the Mercury there are several jumpers to select different power sources...
In the SE it would be obvious to have everything powered through the PDS connector. On the Plus you can choose to get power through the 68000 clip or an external power supply.
It's the same with Quik30 I got in my Classic which needs a secondary power supply to work at all as there is no power supplied to the accelerator through the clip that goes onto the logicboard CPU.
Link to post
Yeah... I d/l'd and saw they were Mercury-specific... drat!
Feared that as well... I know a couple of MLA'rs have one of these... but set up for a Plus - the ones I've seen do have a chip at U4. :-(  My only hope is that it's only required in "Plus" mode... but that's likely a wild hope...
Yeah... I've been wondering that too... I'll see if I can do some probing...
Thanks for the info / suggestions!
Edited by mg.man
Link to post
Doesn't look like it's a VCC issue... compared this 'board to my [working] Mercury 030 and the +5V pins from the PDS are carried onto the 'board.  In fact, they are connected to the two right-most pins of the power connector...  :-(
Link to post
  • 2 weeks later...
On 2/3/2021 at 7:53 AM, uyjulian said:
There's on-board RAM. The bus is going to be the bottle neck
This might be problematic for Macs, since the video circuitry in the BBU expects to find the framebuffer in the DRAM chips, not on the other side of the BBU, in the CPU socket. Maybe it'll need special pass-through RAM regions.
Link to post
  • 68kMLA Supporter
Huh. This is actually kind of a nutso project (in a good sense). One thing that's interesting, is that the CPU is configurable via software apparently, including the ability to control the speed, control whether the onboard 32 byte RAM is available to the host computer, etc.  Take a look at the developer's blogs, especially the one about "Amiga-ness".
https://www.buffee.ca/home/
Quote
If your existing 68000 can do it, then Buffee can do it. Just some 2000 times faster. But I did say that Buffee is not “Amiga specific” and that we cannot support things like Autoconfig, didn’t I? Well, I meant that the memory and peripherals INTERNAL TO BUFFEE cannot be automatically enabled and used by AmigaOS. Or EmuTOS. Or Mac System. Because they all do this differently and they all expect memory and peripherals in different locations.
What this means is that from a default state, Buffee will operate in “ultra compatible mode” and will require that the user or retailer preconfigure Buffee before hand. This includes such things as
  • Enable CPU local RAM in 32-bit memory (disabled by default)
  • Set the location and amount of this RAM
  • Enable data and/or instruction caches for any memory block (by default only the instruction cache is enabled in 24-bit memory, all caches are enabled for 32-bit memory)
  • Enable PJIT instruction cache for any memory block (by default, PJIT ICache is enabled only on 32-bit memory)
  • Set the CPU base clock PLLs (presets for 275 to 1000 MHz)
  • Set the CPU clock divider (from 1 to 1/256th of the base clock)
  • Select between 68000 or 68030 instruction set (68000 default)
  • Select between No FPU, 68882, 68040 or fast 68040 FPU modes (No FPU is default)
  • Enable 68K MMU emulation
  • Preload and remap up to a 2MB ROM image (with or without 68K MMU enabled)
None of these settings need to be set by a CLI utility on each boot (though they can be); these can be saved into the EEPROM memory which will be retained while powered off
I'm probably just projecting wishes here, but I'd be really happy with something I could put into a Mac Plus, tune it to say 50mhz, use the existing Gemini extensions/control panels, and not have spent $1500 on that 030 Mac Plus on eBay.
Link to post
  • 3 weeks later...
  • 68kMLA Supporter
Posted (edited)
Not to resurrect a thread that went into the weeds about Buffee, but:
I would really love some way to connect an SE/30 PDS slot to an FPGA board for experimentation! 'twould be fun to hack with, even for reasons other than accelerator cards.
Anyway, I know there isn't a '30, '40 etc soft core floating around, and I'm only a beginner teaching myself digital logic and FPGA design, but what the hell, what's the worst that can happen other than learning through mistakes /shrug
Edited by rplacd
Link to post
Off the top of my head, the first thing required would be a prototyping board like we had back in the day. They were for wire wrap, some were bare for the PC and some had the expansion logic to slot interface circuitry ready to populate on the board. We've seen SE/30 protoboards crop up, but of the bare sort for wire wrap.
IIRC 030 PDS requirement specs buffering as close to the slot connector on the card as possible. From there anything goes within specs outlined in Designing Cards and Drivers for the Macintosh Family 2e.
Physical interface should be easy enough. I'd prefer it to be more accessible, user friendly and a lot more cost effective setup than stacked EuroDIN-120 monstrosities, but that's another bridge to cross.
Link to post
  • 68kMLA Supporter
Did a sanity check reading that – 120 pins??? Holy hell, who has an FPGA development board with that many pins available for external use?
Link to post
  • 68kMLA Supporter
Posted (edited)
I've looked a couple of times.  The answer is pretty much no one.
Someone trying to plug an FPGA into a Macintosh PDS slot would really need to build a custom development board.
There are plenty of I/O pins available on affordable FPGAs.  They just don't get pinned out on development boards.
Often, the existing development boards will come with schematics, so one could build an identical board that also brings additional I/O pins out to a 120 pin DIN connector.   That way, things like memory and such are already handled by the existing design.
Could be problematical though if the pin choices of the development board don't cooperate well with what you need for the Mac development.
Edited by trag
Link to post
  • 68kMLA Supporter
Posted (edited)
Did a little internet shopping for off-the-shelf dev boards that might work, just for fun.
iCE40HX8K-breakout-revA-front-2400.ashx
If you want to do a lot of work for a relatively low price, Lattice has the iCE40-HX8k breakout board that exposes 4 * 40 = 160 IO pins. So 120 for PDS, which leaves barely enough for memory, 40 pins for DRAM or whatever (not including power supply pins.) Solder in 40-pin headers, stack a daughterboard on top, who knows. But what can you do in 7680 logic blocks?
If you have a Terasic dev board with an HSMC connector (which cost multiple $100s, are only on their higher-end dev boards), Terasic sells a breakout board, the GPIO-HSTC CARD with 3 * 40 pin connectors. It connects using some multi-purpose interconnect that's specific to high-end Terasic dev boards. Of course for the price you'll get the luxuries of a high-end dev board, e.g. literally all of the IO ports you'll need, metric tons of RAM and ROM, an ARM SoC, blinky lights etc. etc. etc.
Edited by rplacd
Link to post
On 1/6/2021 at 6:53 PM, johnklos said:
Second, they don't care very much about compatibility. FPU support was a very low priority, and it appears that they're not interested in MMU support. This means that virtual memory is not possible, nor is running NetBSD, GNU/Linux, nor A/UX. This would also mean it'd be more difficult to add memory pools to Mac OS because Mac OS usually requires sequential memory
Well AmigaOS doesn't really need an MMU so it's not a high priority for them. The core actually has some form of it, but more akin to the ColdFire one (the TLBs and that's it) and it's not exposed yet. They know I'm interested in MMU support for Haiku someday, so who knows…
Edited by mmu_man
Link to post
  • 68kMLA Supporter
Posted (edited)
Not nearly. I've done a few small things with this board and build an SDRAM board and a VGA output for it, and I think every third or fourth pin on the connector is ground, plus a bunch of the pins on the connectors are also connected to other things on the board, like the configuration flash and the on-board UART.
But I don't think the LC PDS actually uses 120 pins either. You're going to have to dig a little deeper into the schematics to find out.
Edited by paws
Link to post
  • 68kMLA Supporter
Ah, drat! Welp, I guess I'll stay up for another hour searching the internet...
96 pins for the '020 PDS interface – I looked it up in Designing Cards and Drivers for the Macintosh Family, v3.
Link to post
  • 68kMLA Supporter
Yeah, but look at the actual pinout. It's a 96 pin connector, but a bunch are used for ground and power, and so won't be connected to the FPGA.
Link to post
  • 68kMLA Supporter
Oh, stupid me, you're right. That's what I get for posting late at night. Least I can do is actually look it up.
I'll be lazy and give a ballpark figure – I think 9 power pins (including fan voltage supply), plus an FPU select pin. So we can get away, conservatively, with 86.
Ack, I'll look over this more properly in the morning!
Link to post
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
