Jump to content
LC III Power Supply Clicking...
Recommended Posts
18 hours ago, Iesca said:
Ah, that's good to hear, I will give that a shot. And a part list would be fabulous, thank you!
Attached is the list of caps I ordered (and used) for the three different types of LC PSUs that I had in my collection of LCs.  (Astec, TDK and Dynacomp (which was a new one for me).
I've recapped about 9 units with this list and haven't had any issues.  The clearance for the big filter cap is a bit tight height-wise for one of them, but everything still went together perfectly fine.
Mac LC PSUs Distribution.xlsx
Link to post
Share on other sites
Here's what I ordered and some relevant information.
Maccaps
PSU Voltages
All caps are radial through hole.
Core:
- 1x 270uF 10V 6.3mm diameter 11.2mm length
- 2x 270uF 25V 10mm diameter 12.5mm length
- 1x 56uF 25V 5mm diameter 15mm length
Secondary (as per 68kmla):
- 3x 1000uF 10V 10mm diameter 16mm length
- 1x 47uF 25V 5mm diameter 11mm length
- 1x 10uF 50V (replaces C8 at 8.2uF 50V) 5mm diameter 11mm length
Please note that I have not actually managed to get my PSU to work, though it remains to be seen whether it's a PSU or a logic board issue. For me, the fan spins and the speaker clicks every second or so, in time with the PSU clicking.
Link to post
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
