Jump to content
Free Macintosh Plus!
Recommended Posts
Several months ago, when I was first getting into this compact Macintosh thing, I posted on Facebook asking if any of my friends had one. I ended up buying an SE FDHD and restoring it, but in the meantime, one of my old coworkers told me he had an "old Mac". We were finally able to co-ordinate tonight so I could pick it up, and here it is!
Apparently, this came out of an aircraft hangar. There is a mouse, 2 power cords, and keyboard cord, but sadly no keyboard. Condition is rough... there's some melted plastic on the top, and it is really really really dirty. It's covered in a very sandy dust... possibly paint overspray. In fact, there's overspray on the mouse. The battery leaked a tiny bit, but there's no significant damage to the battery compartment.
I have decided to NOT attempt to power it on tonight, due to the pervasive sandy dust. I'm mostly worried about the floppy drive (which looks to have a disk in it). Before I attempt to power it on, I think I'll completely take it apart and clean it out, with special attention to the floppy drive. I'll also double-check J1 to make sure it isn't burned or cracked. Maybe reflow some joints on the analog board. I'll also clean the Flight Simulator disk to see if it works, my buddy said he grew up playing that on it.
I'm also wondering if I could do a series of YouTube videos about it. Shooting video is easy... it's editing that I find to be a lot of work. I have lots of video from my Macintosh SE but haven't found time to make it into a video. If you have thoughts on that, let me know.
Link to post
Share on other sites
  • Replies 73
  • Created
  • Last Reply
Top Posters In This Topic
31 minutes ago, LaPorta said:
128k or 512k upgraded to a Plus...we will need to see what's inside!
Whoa, very good catch. That had escaped my notice. What is more desirable, replace the case with a nicer Macintosh Plus case (note melted plastic on the top), or restore the original 128k/512k case? I'm thinking retrobrite, clean up the burn mark a bit by carefully heating and bending it back, maybe spot-sanding it a bit to smooth it out. It'll never look perfect again but it could probably look nicer with some careful work.
Link to post
  • 4 weeks later...
Ok, I finally had some time today to work on the Macintosh Plus! Sadly, it's not up and running (yet). But here's the journey for how I got to where I am now (bong, no display, floppy flup-flup-flup, half-hearted floppy eject).
I started by wiping it down. Check it out next to my fully restored (and retrobrighted) Macintosh SE FDHD.
The case took a bit of effort to pop off, especially since the melted plastic on the top fused together a bit but it did come off cleanly.
Oh, sweet! $1.50 off at Dominoes! Expired in 1995 though... dang.
Logic board and floppy out. Blasted the logic board with compressed air, along with the rest of the Macintosh.
Time to clean out the floppy drive.
This disk as been in here for a long time. The platter(?) has one very dusty stripe where dust continuously got on it. TBH, the drive wasn't as nasty as I thought it would be.
I took apart the drive and cleaned it. Scrubbed metal parts with soap and water, lubricated everything with lithium grease, and put it back together. Made sure disks ejected smoothly. I also pulled the cover off the eject motor mechanism and it looks great. I put a couple drops of Silicon lubricant in there (I primarily use it on the linear rails on my 3d printer).
Reassembled, attempted to power on aaaaaaaaaand:
  • Bong
  • Flup-flup
  • Half-hearted floppy eject (can't remove the disk, it's stuck in there)
  • No video, no raster
Slapping the side of it while it's running doesn't produce video. I did not check J1 for cracks, as it has the shield double-side-taped down. I wish I would have now!
I'm pretty comfortable working around my SE FDHD because I think it has a CRT bleed-off resistor... but the CRT and analog board on the Plus, I am less comfortable with. I am not a big fan of the "massive loud blue spark" on CRT discharge thing (my SE has never done that). How long should I let this thing sit for before going through the discharge procedure before doing that? I'm happy to wait, I'd really rather not mess with high voltages if I can.
Edited by PotatoFi
Link to post
I’m fairly certain this has to do with voltage adjustments. Could be as simple as adjusting a potentiometer, could have to do with capacitors. You’ll need to test the voltages at the main logic board connector and see what you have.
As for the discharge, you need to make yourself a tool with a screwdriver, wire, alligator clips, and a resistor to ground the thing off. It will bleed off the charge without a pop. If I recall, I think it is 1/4 watt rated, 10 megaohm resistor.
Edited by LaPorta
Link to post
I don't think you would get the bong if the voltage was so low that you would have no video. On my Classic, I wouldn't get the bong below ~4.5V, but I still got (admittedly wavey) video. The floppy was also functional at that voltage.
Link to post
Ok, here's what I've done this evening:
  • Freshened up the solder at J1
  • Measured voltage at floppy connector: 4.9v and 12.08v
  • I adjusted the voltage using the voltage potentiometer, it is now 5.0v and 12.3v at the floppy connector
The screen is still dark. Before adjusting the voltage, the floppy drive did successfully spit out the random floppy disk that I had in it! It now ejects it reliably after attempting to read the disk. I'm not sure why it failed the first time but the floppy drive seems happy now.
Funny, this is identical to the issue my Macintosh SE FDHD had. Everything seems to work, but the display is dark. On the SE it turned out to be a broken leg on a filter.
Link to post
2 minutes ago, LaPorta said:
Sometimes that noise is actually from an over voltage to the video circuit.
Which noise? Other than the floppy drive, it's pretty much silent. I do hear a "CRT sound" when it's powered on... classic sound of a CRT coming on.
Link to post
  • 3 weeks later...
I've been out of town for work a lot, so the Macintosh Plus has not received a lot of attention. Soon I'll take it apart, discharge the CRT, make a list of capacitors from the analog board to order, and retrobrite the case (probably full submersion method).
I did spend some time on the mouse and the keyboard (not the original keyboard, I purchased this separately). The keyboard was in pretty good shape, but the mouse was severely discolored and had pink paint overspray on it.
Overall, the mouse turned out pretty good. There's a bit of marbling from the retrobrite but it's very hard to detect. On to the keyboard (less dramatic):
This keyboard is probably the worst retrobrite job I've done... the spacebar shows marbling. That said, it looks pretty dang good. I'm glad I did it. You have to look very closely to see the marble. I DO think this is the wrong keyboard for this Mac. I would like to find the original keyboard so the color matches the 128k case. We'll see.
Link to post
Meh, the Rev 1 and Rev 2 Beige Plus had earlier ROM versions with SCSI bugs. The Rev 3 Plus in platinum is, IMO, the best one, since that was the final ROM revision where they finally got the SCSI bugs out.
Edited by Paralel
Link to post
No pictures to share on this update, but here's what I've done:
  • After letting it sit for 3 weeks, I took it apart, discharged the CRT (no pop), and completely disassembled it
  • Cleaned entire case with dishwasher detergent and a toothbrush
  • Scrubbed black marks and paint overspray off with a wet rag and baking powder
  • Performed full submersion retrobrite under a UV lamp (it didn't do much... I think the cold in my garage inhibits the process), decided that it looks "good enough"
  • Ordered new capacitors for the analog board
Tonight I'm going to play with the hairdryer and bending the plastic burn back into shape. I messed with it a bit this afternoon and found that while I could slightly soften the plastic, I couldn't really get much to happen. If you have any tips, let me know.
Edited by PotatoFi
Link to post
Cold absolutely will work against you. You need UV + at least room temperature 72 F/22 C. Those are essentially the two variables you can control intensity of UV and heat. The stronger the UV, the faster and stronger the reaction, up to a point. Also, more heat the faster the reaction will occur, up to a point.
Regarding heat to move the plastic, if you can, use a highly controlled heat source where you can set the temperature. There is an extremely fine point between making it soft enough to remold, and just too much, where the texture of the case starts to get lost due to it becoming too amorphous.
Edited by Paralel
Link to post
10 minutes ago, Paralel said:
Cold absolutely will work against you. You need UV + at least room temperature 72 F/22 C. The more heat you can provide the faster the reaction will occur, up to a point.
I have to wait a few days for capacitors to arrive anyway, so I might bring it into the house where it is about 70 F and give them some more time. What's interesting is that it's more white where I scrubbed things off using baking soda, probably due to the slight abrasive nature of the baking soda.
I'm curious, what reference do you have for the 72 F/22 C thing? Personal experience is completely valid here.
Edited by PotatoFi
Link to post
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
