macclassic Posted November 16, 2013 Report Share Posted November 16, 2013 (edited) I've just noticed that the startup bong on my 6100/60 has got quieter! If this is caused by caps can someone please tell me which one's ? Edited November 16, 2013 by Guest Quote Link to post Share on other sites
Ike Posted November 16, 2013 Report Share Posted November 16, 2013 Could very well be the logic board caps, however, the 9600 also is very quiet when starting the first time without a PRAM battery. How is the rest of the sound volume after startup? It's always a good idea to recap the board anyway, as the leaky caps will keep on doing more damage when they keep leaking. Quote Link to post Share on other sites
macclassic Posted November 16, 2013 Author Report Share Posted November 16, 2013 The other sounds are good it's just the startup bong and this was a new board* a few years ago. Can I find the Bong with ResEdit? *the original had an irrepairable video socket problem. Quote Link to post Share on other sites
macclassic Posted November 16, 2013 Author Report Share Posted November 16, 2013 Just remembered, It's got an L2 cache card fitted and I think I had to install some fix with this cache but can't remember what it was? Quote Link to post Share on other sites
LCGuy Posted February 1, 2014 Report Share Posted February 1, 2014 The startup "Bong" is burnt into ROM and cannot be found in ResEdit. Quote Link to post Share on other sites
uniserver Posted February 1, 2014 Report Share Posted February 1, 2014 my 6100 still has original caps, i don't think they are leaking yet… but they are domed at the top. I am thinking these old powermac's are going to all need re-caps soon , as the years roll on. Quote Link to post Share on other sites
Recommended Posts
Join the conversation
