Jump to content
Homebrew PRAM Batteries
Recommended Posts
  • 68kMLA Supporter
On 4/10/2021 at 8:04 PM, jessenator said:
3x LR44 battery holder
Are these available from somewhere? I’d love a smaller than 3x AAA holder for my 630 and 6360.
Link to post
Share on other sites
  • Replies 53
  • Created
  • Last Reply
Top Posters In This Topic
  • 68kMLA Supporter
Well, mine is a 3D print and requires a bit of DIY-wiring. Here's the printable file I used: https://www.thingiverse.com/thing:81229
Stole the bit of velcro off the bottom of a 4.5V brick, used a bit of sticky tack for extra security, but I might just hot glue it...
It looks like there's provision if you had a board-mount solution... but I just needed something hold them. It's a bit bodgy, but I get 4.5 (~4.6-4.7V on my Fluke) from the wire terminals. We'll see how it holds up after I solder and heat shrink the old battery's leads :lol:
Link to post
  • 4 weeks later...
  • 68kMLA Supporter
I recently bought a pack of these 2032 holders with switches and a length of wire. They worked perfectly for the IIx, where the batteries are underneath the drive bracket and are also needed to boot the machine. I soldered them to the battery holder leads and then routed them above the drive bracket and mounted with velcro. Works great. Easy to access and you can turn them off when putting the machine into storage.
Link to post
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
