iamdigitalman Posted June 24, 2008 Report Share Posted June 24, 2008 I don't even know if this would be, but hear me out: The newton handwriting recognition lives on in Mac OS X as inkwell. It only shows up when you plug in a graphics tablet. There are ways to hook a newton up to Mac OS X to sync it. What if when you plug in a newton, you run an app on it that makes it emulate a graphics tablet, so you could use it's touchscreen in OS X's inkwell. This is all assuming someone can write an app for the newton that would make it send it's tablet data through the serial port (or someday, over a wireless connection like wifi or bluetooth). What does everyone think? I assume if it were to work, the newton's touchscreen would be recognized by inkwell because the two are related, but not entirely sure. Hey, one can dream. -digital Quote Link to post Share on other sites
~Coxy Posted June 25, 2008 Report Share Posted June 25, 2008 Someone did actually do this, in the Classic OS of course. So it'd certainly be possible, although improbable. You would need to write an advanced enough driver that made the Newton look like a Mac serial tablet to OS X. Then you'd also need a USB/Serial adaptor for any hardware newer than a beige G3. Quote Link to post Share on other sites
Da Penguin Posted June 25, 2008 Report Share Posted June 25, 2008 More realistically you could enable ink as is on the mac, then install vnc server and client on the machine and newton respectively. Sure it might be a bit laggy, but it will be a heck of a lot easier/faster to set up. TBird Quote Link to post Share on other sites
Recommended Posts
Join the conversation
