davidg5678 Posted September 1, 2017 Report Share Posted September 1, 2017 (edited) I attempted to Retrobrite my Macintosh SE using the 8-Bit Guy's method of 40 volume developer and plastic wrap. (see here: https://youtu.be/VU7vXMezW_I) It failed miserably and left my entire Mac looking like a marble sculpture. During the process, I cleaned my computer thoroughly -first with a garden hose which I followed up by isopropyl alcohol. I was sure to massage the cream around every half hour while it sat in very bright sunlight for about 4 hours. It stayed this way for a few months until I tried fixing it with total submersion method recently shown by the 8-Bit Guy (https://youtu.be/qZYbchvSUDY) skip to 16:15. This time, I used 2 bottles (64 ounces) of peroxide to try and offset the massive difference in water that the 8-Bit Guy had for his Macintosh LC. The marble effect seemed to clear up when I was outside, and from its appearance, the computer looked normal. I rinsed off the water and peroxide and dried off the computer -only to see that there was no difference in the marbling. The surrounding plastic looked a tiny bit brighter, but the marbling is very visible. This was also outside for four hours. Is there something I did wrong during the initial Retrobright process that caused my computer to look the way it does? Does anyone know what I can do to fix this issue? Was the second treatment not strong enough? Pictures of the disaster below: Edit: Images added Edited September 1, 2017 by davidg5678 Quote Link to post Share on other sites
Alex Posted September 1, 2017 Report Share Posted September 1, 2017 Using Saran Wrap is the dumbest method. I tried it on a keyboard and the results were exactly the same. I will never use the method again. I use a paint brush, takes long but works. Quote Link to post Share on other sites
Juror22 Posted September 1, 2017 Report Share Posted September 1, 2017 (edited) I'm sorry this happened to you. I would never use any creme method, period. There are plenty of other methods that work, without the danger of mottling, do a search on the forum for more of them. I know that you have learned this lesson, but for those who come after... Never, ever, ever ever, experiment with a method that you have not tried first on stuff that you don't care about. This goes for retrobriting, soldering, removing capacitors, pretty much everything associated with this hobby. Work on a test piece first. I don't think that more retrobrite is the answer, since the mottling is from areas that are over-bleached. Over-bleaching the entire bucket may give you a unified color, but it will never be a natural one. Alternatively, I suppose that you could see if belgaonkars SE/30 shell would work for you, or you could look for another SE bucket from some member or else from online. Edited September 1, 2017 by Juror22 Quote Link to post Share on other sites
falen5 Posted September 1, 2017 Report Share Posted September 1, 2017 (edited) i tried a bit of retrobrighting recently as well had mixed results some good , some like what you got i found that if you use the cling film you have to keep going back to it every 5 minutes, lift the film, and keep spreading the goo. keep working it. dont just let it sit in the sun for hours without checking on it. The sun in ireland ( when it decides to show itself) can retrobright a case in 30 minutes. I did a color classic last month. I could literally see the case changing color by the minute on the color classic, as the color was getting brighter i could see those patches forming. Lifted the cling film, used a small paint brush, and just spread the goo everywhere again. Only small amounts. The patched i was getting were the same as what you have, but i kept re-spreading the goo, kept am eye on it, and ended up with a perfect retrobright. If i didnt keep checking it , it would of ended up like yours. I found that by tilting the case you can see where the goo/solution is and is not. Within 1 hour the case was like new. However! !!!!!!!! I tried the same on an atari st case using same process - disaster. This time i ended up with patched as well, but these patches were brighter than the original color. The peroxide goo had actually bleached the plastic, brighter than its original color. So far i cant see a way to undo this damage, except maybey to let it in the sun for 10 years to go yellow again. You can try different polishes but it wont fix the problem. The case was beyond rescue so i decided to experiment with it. I took a small bit of p200 sandpaper to the bleached parts, did a bit of sanding and the original color come back. But this destroyed the original finish of the plastic. Then broke off another bit of the bleached plastic and took a look under a scope. my eyes are not the best but from what i saw it looked as if the plastic has basically melted from the peroxide. Even the surface finish felt different. I think it all comes down to the plastic itself and what additives were used in creating the batch. ABS is what most computer cases are made from. There are many many additives in plastic, plastizer, uv stabilizer, fire retardents etc etc. Long story short , if i want to retrobright something , take the case in question and TRY A SMALL TEST PATCH ON THE INSIDE OF THE CASE FIRST I have done a few cases so far and cant see and consistancy in the process. I am using the same peroxide goo, clingfilm and process, but get different results, mostly good, each time. Id advise anyone who wants to retrobright their beloved machine do a test patch first. Dont cover the entire case and hope for the best. You could ruin the case And when I say ruin , i mean it. You could end up with a case that is 40 shades of cream. Ugly !! Retrobrigting does work, but not on all plastics. Be warned. Edited September 1, 2017 by falen5 Quote Link to post Share on other sites
falen5 Posted September 1, 2017 Report Share Posted September 1, 2017 (edited) davidg5678 - there is a solution for your case the original color can be restored by sanding. You will loose the surface finish but you will get a consistant color all round. just get a bit of 2x1 and some p100 sandpaper and get stuck in. finish it off with p200 and it will be as smooth as a babys %$£" you will have to do the whole thing. I was going to do it to the atari st i mentioned above, but there were loads of thin, strips( like a vent) on the case and would of taken to much time give it a shot. Your case will end up looking like a brand new prototype case!! Edited September 1, 2017 by falen5 Quote Link to post Share on other sites
davidg5678 Posted September 2, 2017 Author Report Share Posted September 2, 2017 (edited) I appreciate the quick responses. I decided to use the idea of sanding the plastic. I used 150 grit and 220 grit sheets and went all around the case. I sanded every part of the case until the streaking was bearly visible, and touched up/smoothed with the finer grit paper. To my surprise, the texture of the case did not come off as much as I thought it would, and I was left with a significantly better-looking case. The streaks are still bearly visible but are faint enough not to bother me or be noticeable. Because I was able to avoid all of the stickers on the back of the computer, they look normal. However, I lightly sanded the words Macintosh SE and somehow made them vulnerable to rub off with isopropyl alcohol. I would appreciate any suggestions on how to fix this. Besides the lettering issue, I would highly recommend using sandpaper to remedy a similar issue. Below are some pictures of the computer after I have sanded it down. Edited September 2, 2017 by davidg5678 Quote Link to post Share on other sites
Juror22 Posted September 2, 2017 Report Share Posted September 2, 2017 Looks good in the pics, even close up. Nice save! Quote Link to post Share on other sites
joethezombie Posted September 2, 2017 Report Share Posted September 2, 2017 i have a mac that the previous owner tried to clean and took off the name. i’ve been meaning to try some Palissade transfer paper and restore it, but haven’t gotten around to it. Quote Link to post Share on other sites
falen5 Posted September 3, 2017 Report Share Posted September 3, 2017 (edited) Great Job man. dont know if it would work, but how about printing off the SE/30 logo, on a label sticker, and make a stencil out of it. You would have to , by hand, cut out the letters. If its good enough , peel off the back and stick it in place , mask off the rest of the machine, and get a tin of black spray paint - 2 or 3 shots from the right distance , let it dry Theres probably a much easier way id be happy with the case as it is! How long did it take to sand ? good recovery. Edited September 3, 2017 by falen5 Quote Link to post Share on other sites
Alex Posted September 3, 2017 Report Share Posted September 3, 2017 I decided to use the idea of sanding the plastic. Damn, I meant to come back and edit my reply earlier. If you had gone through another retrobrite phase it would have likely saved it. You see, the light areas in those patchy areas wouldn't go lighter then the original color of the plastic but those darker patches would have continue to lighten. This is how I fixed a keyboard that ended up like your mac, I just ran it through another phase of brightening with another application using just a pain brush. Sorry that you had to use sandpaper. Quote Link to post Share on other sites
el_jeffe Posted September 20, 2017 Report Share Posted September 20, 2017 I did the same exact thing, see my post here: https://68kmla.org/forums/index.php?/topic/30384-retrobrite-fail/&do=findComment&comment=329207 I used a headlight restorer kit and finally got it back to normal minus the surface texture. I underestimated the power of the sun. Also tried the keyboard to the SE Superdrive and got same results on the frame but the keys came out ok. Unfortunately after a couple of months they're yellow again. Quote Link to post Share on other sites
jongleur Posted September 20, 2017 Report Share Posted September 20, 2017 (edited) My preferred retrobriting is http://www.callapple.org/vintage-apple-computers/apple-ii/shining-a-light-on-retrobrite/and Javier has demonstrated it at the past 3 KansasFests https://www.kansasfest.org/ and the last KansasFest demonstration was also recorded on Assembly Lines #52 https://www.google.com.au/url?sa=t&rct=j&q=&esrc=s&source=web&cd=2&cad=rja&uact=8&ved=0ahUKEwjuo-uO47LWAhUIgLwKHXtUDtkQtwIILjAB&url=https%3A%2F%2Fwww.youtube.com%2Fwatch%3Fv%3DaFGS9xaaO_M&usg=AFQjCNEIW4nJDIw7rCty3vx475GPM_1z9Q Always test with something expendable, or less precious, and keep an eye on it. You cannot just leave it alone. Edited September 20, 2017 by jongleur Quote Link to post Share on other sites
olePigeon Posted September 20, 2017 Report Share Posted September 20, 2017 You might be able to fix the lettering by buying some water slide decal paper and printing the "Macintosh SE" text. You could then apply the decal. You'll need to be careful and make sure it's exactly the same size & font. Practice with some thin paper (or even better, a transparency) Quote Link to post Share on other sites
Trash80toHP_Mini Posted September 20, 2017 Report Share Posted September 20, 2017 I've seen some interesting things being done over on Fine Scale Modeler. Don't remember what or where, but that's where I'd start doing research on transfer lettering. As an ex-sign painter/screen printer, I'd definitely go the screen printing route, but that's not for everyone. As a second choice, I'd cut the copy in thin, high performance vinyl, apply transfer tape without weeding it. Transfer the vinyl to the case and then weed out the lettering leaving the "waste" as a stencil. Hopefully you can find a can of gray spray paint that's a close enough match. Give it a couple of very light coats and then peel the vinyl masking. There will almost certainly be a ridge along the edges, but it could very likely be remedied with Q-Tips, mild abrasive and TLC. YMMV, so try it on the case bottom first using Scotch tape to simulate the vinyl. Once you have the artwork done in Illustrator or the like, it'll probably be a minimum charge job to get some multiple copies cut. I'd lay it out so that the vinyl would be a panel that would register top, bottom and side without measurement needed for application. Quote Link to post Share on other sites
cbmeeks Posted October 5, 2017 Report Share Posted October 5, 2017 I really like the 8-bit Guy's show (and I've been a Patreon donor for him too) but people really do need to remember that not everything he says is accurate or highly scientific. Granted, I don't have my own show with lots of fans so take what I say with a grain of salt. I'm sure he's had success with his cling wrap method but I would never do that myself. I tried doing that to an Amiga 500 once and it came out awful. Total submersion is really the best way. I used to use cream but not any more. Now for keys, I once created a rig to hold the keys upright and prevent them from floating. I then covered them with peroxide liquid in a glass bowl for a few hours and they worked great. The trick, however, it uniformity and consistency. Meaning, don't treat some keys for 4 hours and other for 6 hours. You'll get different shades. They all need to be done at the same time. Extra treatment for the ones that are stubborn but only in small doses. Retrobrighting is a slow process. And, it's not permanent. I've been toying with an idea on how to submerge classic Mac's. One idea is to get a large clear container that is just big enough to hold the Mac but have enough room around the sides so that UV can get there too. Then, find something that doesn't float to fill in the empty space inside the Mac. Something that is water tight and form-fitting for the inside. That way, you need less water/peroxide to fill the container (less volume). Then mix the strong stuff with water. One thing people seem to forget is good old-fashioned painting. Granted, painting isn't an option many times. Especially where lettering is involved. Plus, it's harder to do and not come out like crap. But it can be done and when done right, is very permanent and awesome. If you could find the exact font for the front cover (of classic Mac's, for example) then it should be easy to create a stencil that can be painted. Quote Link to post Share on other sites
TjLaZer Posted April 6, 2018 Report Share Posted April 6, 2018 Magic eraser can help fix that better than sand paper. The best method I have found is to use 40 volume clear conditioner and a small brush. No need to dismantle the computer either. Apply thin coats and leave it in the hot sun! Reapply with the brush every 15-20 min for several hours! Yes it's a pain! BUT no marbled looking relic. Then wipe down with some simple green and a lint free cloth and rinse with clean damp cloth until it's all off. I do this for all my retro computers, even keyboard keys. No issues. Just have to be careful not to brush on too much that it leaks inside. Quote Link to post Share on other sites
SE30_Neal Posted April 8, 2018 Report Share Posted April 8, 2018 On 01/09/2017 at 2:52 PM, davidg5678 said: I attempted to Retrobrite my Macintosh SE using the 8-Bit Guy's method of 40 volume developer and plastic wrap. (see here: https://youtu.be/VU7vXMezW_I) It failed miserably and left my entire Mac looking like a marble sculpture. During the process, I cleaned my computer thoroughly -first with a garden hose which I followed up by isopropyl alcohol. I was sure to massage the cream around every half hour while it sat in very bright sunlight for about 4 hours. It stayed this way for a few months until I tried fixing it with total submersion method recently shown by the 8-Bit Guy (https://youtu.be/qZYbchvSUDY) skip to 16:15. This time, I used 2 bottles (64 ounces) of peroxide to try and offset the massive difference in water that the 8-Bit Guy had for his Macintosh LC. The marble effect seemed to clear up when I was outside, and from its appearance, the computer looked normal. I rinsed off the water and peroxide and dried off the computer -only to see that there was no difference in the marbling. The surrounding plastic looked a tiny bit brighter, but the marbling is very visible. This was also outside for four hours. Is there something I did wrong during the initial Retrobright process that caused my computer to look the way it does? Does anyone know what I can do to fix this issue? Was the second treatment not strong enough? Pictures of the disaster below: Edit: Images added I used the same process small brush, 40% volume cream, cling film. I didn’t even take it apart just put it on lightly so it didn’t go in to the holes, cling filmed it and left under uv for 3 hrs checking every hr. did this to my se/30, keyboard, mouse, CD-ROM and performa 6200 on my kitchen table. Maybe the uv isn’t as powerful Quote Link to post Share on other sites
SE30_Neal Posted April 9, 2018 Report Share Posted April 9, 2018 Can you not use a small brush and paint the darker bits to level it out abit? Quote Link to post Share on other sites
rickrob Posted April 9, 2018 Report Share Posted April 9, 2018 When you used the plastic wrap-- were there lots of wrinkles? I just did the plastics on a Laserwriter II and noticed that where I had wrinkles ended up with a similar effect to your SE. Not as bad, however. I reapplied the 40 developer and smoothed out the plastic wrap and was able to even things out. Quote Link to post Share on other sites
Unknown_K Posted April 10, 2018 Report Share Posted April 10, 2018 I think those swirl marks are from the plastic when it was injection molded and they show up when you over do it with oxidizers. Quote Link to post Share on other sites
SE30_Neal Posted April 10, 2018 Report Share Posted April 10, 2018 I think there is a level of that in the plastics to start with, i would re-do it with a light application and keep checking it every 12-20 minutes and also do on a not so sunny day or on your kitchen table by a window Quote Link to post Share on other sites
AlpineRaven Posted April 10, 2018 Report Share Posted April 10, 2018 I've been retrobrightening - same thing happened to me as above, lesson learnt - ever since Ive refused to do it in the sunlight, I'll do it under UV lamp and it doesnt not cause streaking. I did do submerge retorbrightening under the sun and had good results. At the end of the day - I'd rather do it under UV. Cheers AP Quote Link to post Share on other sites
SE30_Neal Posted April 10, 2018 Report Share Posted April 10, 2018 Not had a problem under uv either but in the uk the weather is rubbish so had to do it inside anyway and that worked i think the uv light was £10 so wasn’t expensive Quote Link to post Share on other sites
Bolle Posted April 17, 2018 Report Share Posted April 17, 2018 I did some experiments with brighting up some plastics as well. I started with two M0118 keyboards to get a feeling for the whole process. Was just using 12% hydrogen peroxide cream and did spread a very thin layer of the cream using a fine paintbrush. I was using a bigger brush at first but this resulted in fine streaking that is only visible if you look carefully. After switching to the fine brush there was no streaking at all. I kept checking back every 5-10 Minutes and reapplied some tiny amount of cream. Doing this for 20 to 40 minutes was already enough. You could see it turning brighter while sitting right next to it. Top half already brightened and bottom half still how it started: After the second keyboard turned out well I tried the bucket of one of my SE/30s. I did each side on its own until they all matched in tone. The back started out more yellow than all the other sides: I did add a tiny little drop of water to the cream to get an even thinner and more evenly spread layer on there. The key seems to be to get the amount of cream right to prevent streaking. Quote Link to post Share on other sites
SE30_Neal Posted April 17, 2018 Report Share Posted April 17, 2018 I didn’t put on a lot either and kept checking every 30 minutes and that worked great Quote Link to post Share on other sites
Recommended Posts
Join the conversation
