Jump to content
Forums
  1. Important Information
    1. The 68kMLA Forum Rules   (9911 visits to this link)
      To quote vintage Apple manuals: "Read Me First!"
  2. Community Connections
    1. General 68kMLA News & Stuff
      3971
      posts
    2. Conquests
      39197
      posts
    3. Trading Post
      52327
      posts
  3. Projects & Hosted Forums
    1. RetroChallenge
      http://retrochallenge.org/
      1482
      posts
    2. 68kMLA Wiki
      The creation and maintenance of the 68kMLA's information repository.
      http://68kmla.org/wiki/
      483
      posts
  4. 68k Model Forums
    1. Compact Mac
      Macintosh, 512k, SE, etc.
      45141
      posts
    2. Mac II, Quadra & Centris
      12850
      posts
    3. 68k LC & Performa
      Ah, the consumer computers!
      7882
      posts
    4. 68k PowerBook
      9724
      posts
  5. PowerPC Model Forums
    1. NuBus Power Mac, LC & Performa
      2636
      posts
    2. PCI Power Mac & Performa
      5856
      posts
    3. G3/G4/G5 Power Mac, iMac & eMac
      13674
      posts
    4. PPC PowerBook & iBook
      8949
      posts
  6. Everything Else…
    1. Apple I, ][, /// & Lisa
      7307
      posts
    2. Newton
      1063
      posts
    3. Software
      17335
      posts
    4. Hacks & Development
      18328
      posts
    5. Peripherals
      14408
      posts
  • Posts
    • @jjclay I too thought the gears might just pull out, but I could only get the little yellow gear and the white one above it out by gently pulling.  I didn't try to apply too much pressure to the other two bigger gears for fear of breaking them, so I look forward to hear the technique you employ on the next drive you service.     I will PM you my address.
    • I followed this video's suggestion to stick an older card into the late 2005 G5, and it works fine.     In Apple system profiler, the card appears under PCI, listed in slot 'GIGE'. Normal PCIe cards are listed in 'SLOT-1', and so on. Edit: not sure why it's in the list twice.   Given that this older card works, that means it's not a PCIe bus at least on the wifi side (older cards like this don't offer Bluetooth). No older Apple computers had PCIe. I suppose the slot could be using one of those PCI to PCIe adapters in the chipset it connects to.   Edit: bcm5714 (as shown in the PCIe device list) is a pci-e to pci-x bridge chip with built-in dial gigabit Ethernet ports. So it's 100% a PCI link for at least some of the card.   I am curious whether the Bluetooth module is listed under USB. Hey @jeremywork, could you check under PCI and USB in the apple system profiler to see how your card appears?   Ignore the date in the attached picture, I just took that this morning without setting the time.   Another fun possibility this brings up would be a card that lets you use a PCI card in the G5. Wonder whether it's specialized to airport only.
    • No problem! Nice to know he's still got that going on the side.   Got them Friday (decided to get both 66.666 and the 71.7948, just to see). and the rest of everything should be here Monday. Also got a solder sucker, so hopefully that plus heat gun makes easy work of the through hole connections.   I'll also have those last two values of capacitor that I missed in my initial inspection of the power supply (but rectified in the parts list), then a working Q700.   Short of finding a TechStep, is there a program that would test the sundry aspects of the system that might be disabled/impaired by an OC over 33 MHz? That wouldn't be identified with a MacBench test or even the Apple Personal Diagnostics? I suppose the only thing relevant to me would be floppy drive control (I'm guessing it effects floppyEmu just as it would a physical drive), ans I don't recall if it does, but perhaps Ethernet.
    • No.    The Portable was designed to run on battery, not without one and not only using the external psu.    So the main goal of the psu is to keep the battery charged, the original psu (1,5) is more than enough to keep that goal.    Using the 2 A is not an issue if everything else is in good condition (Logic board)   the 3 A is to be avoided, the risk is heavy to blow something.
    • Gotcha, so, I imagine it would be annoying if you were using this thing with -RWs to make rolling backups or whatever, but for day-to-day burns, probably not that big of a deal.   "Good enough" CD-Rs are extraordinarily cheap in the US at least. (I've got that 100-stack of Memorex discs, which I bought pretty much because I forgot I still had the remains of the other 50-ish stacks, and that was probably $20 or so when I got it -- and it seems like they're a bit closer to $15 now.) so most of the economic reason to use -RWs is gone, though operationally I know they're more convenient. (see also: coryw fighting with blu-ray media.)   *EDIT: So it depends on what your workflow is, basically.   I don't have any other early CD-RW drives. Have you seen this behavior in others? Like if someone looked for a Que! burner or something in SCSI is this something they'd experience, or a pecularity of this specific Sony device?
