Jump to content
Shymon184
I need help with setting up SCSI2SD in my Mac Color Classic
Recommended Posts
I need help with creating HFS volume on the SD card.
I bought SCSI2SD to replace dead quantum hard disk in my Mac Color Classic. I used this guide to set up SCSI2SD, but I wasn't able to follow it to the end because I have Windows, but I managed to put Lido on a diskette and when I ran the program on the Mac it displayed error saying: "unable to determine size of the volume" (or something along those lines).
My setup is SCSI2SD v5 and 16GB micro SD card, you can see my configuration in the attached files.
Share this post
Link to post
Share on other sites
One thing: if it is the only drive internally (which is what I would think), then it should have termination enabled. Not sure if you set this on hardware or not if it was only a v5. Otherwise, it so far looks ok...but I am by no means an expert here.
Share this post
Link to post
yup, it's the only internal drive and about the termination; the termination resistors are in place, so I have no idea what went wrong...
Share this post
Link to post
If you have the capabilities, getting a patched (meaning modified) version of Apple HD SC Setup can also possibly help you. See if that will format it. Another question is what is on the card already, is there any sort of file system?
Share this post
Link to post
Since I have Windows I can't work with Mac file types (even though I bought iBook G4 for compatibility, it haven't arrived yet, slovak postal service is very slow). The SD card is formatted to NTFS (when I bought it, there was probably FAT32), maybe I should format it to FAT32...
Edited by Shymon184
Grammar
Share this post
Link to post
Are you able to post a photo of the exact message you're getting from Lido? I've never known it to have any issues formatting a SCSI2SD volume. What version of Lido is it? You shouldn't even need to change the vendor or product ID of the SCSI2SD with Lido.
Share this post
Link to post
4 hours ago, Shymon184 said:
I tried your guide and it didn't work :\
Can yo provide a bit more detail?   Did you use DD or BalenaEtcher to write one of my images to your card?
Did you update your SCSI2SD settings to match those I describe in my entry?
Have you done a full format of your card (not a quick format) to see if there were any issues with the card itself?
Share this post
Link to post
I used Lido 7.5.6, here are the error messages in order as they appeared (last one appeared two times in a row).
IMG_0228.thumb.JPG.f100a0e5194c3adbd8223d83e1b20263.JPGIMG_0227.thumb.JPG.faf7d362694b68d9b30d3d82bab567d7.JPG
Share this post
Link to post
I used DD since I have Ubuntu installed alongside Windows, yes I've configured SCSI2SD as you described in your entry and yes I've fully formatted the card.
Share this post
Link to post
I'll get it together for you. I've had varying success with one program vs the other. I think every single SCSI2SD I've dealt with has had different issues to get them to work.
Share this post
Link to post
A couple more questions:
  • What are you booting with now?  A floppy disk?  I also have floppy disk images on my site you can try http://www.savagetaylor.com/2017/12/28/setting-up-your-vintage-classic-68k-macintosh-using-a-floppy-drive/
  • I'm assuming that after using my drive image as device 0, your CC didn't boot?
  • I'm assuming that you don't have another mac to test with?
  • Have you tried providing power to the SCSI2SD using the USB connection instead of the CC's power connector?
  • Is it possible that a capacitor has gone on your CC?   My CC is currently shelved because I started having capacitor issues and haven't had a chance to get it re-capped.
It would be good to confirm that they problem isn't with your CC itself.  You said you started this because your hard drive died, perhaps something else on the CC board failed at the same time.
Share this post
Link to post
  • Apple System 7.5 disk tools diskette.
  • Yeah, it doesn't boot, I need to boot from diskette.
  • Indeed, the only other Mac I have is Mac Plus, which doesn't have internal SCSI bus.
  • not really, but I don't think the power is the problem because Lido recognizes the drive at SCSI 0 but is unable to read drive capacity.
  • it has old capacitors that I'm probably going to replace but it's working fine for its age.
Well, the Mac performs as usual so I doubt that any other component died, and yes I started this thread because the hard drive died, but that's what happens with nearly 30 year old SCSI hard disks (especially the Quantum ones), but dead hard disks aren't important since I need help with the replacement of that disk.
Edited by Shymon184
Grammar
Share this post
Link to post
Power shouldn't be an issue on the internal CC bus...although I will admit, I had a very strange thing happen once: I got the thing to work properly once only by having the USB power attached to it while on the bus, and then formatting it. Then it no longer needed the power...makes no sense!
Share this post
Link to post
Interesting... maybe I should try it, but I have no idea how I'm going to be able to put a micro USB cable inside since there's very little space in the CC.
Share this post
Link to post
46 minutes ago, LaPorta said:
Just leave the back off while you are working on it. I almost never close the machine up until I know everything is working on it anyway.
No success, but I got some interesting results:
Got Arbitration error (3 times in a row) and the Lido recognized the volume, but I wasn't able to format it.IMG_0232.thumb.JPG.71e947a27d150d7eeac73a32165d7300.JPGIMG_0233.thumb.JPG.35d8a82f0347af2897a485230662a830.JPG
Share this post
Link to post
Yes, I had very similar errors as well. I knew that I had seen something similar. Here is my old Classic thread:
Dig through and see the posts regarding the extra power, etc, to get it set. I also started up with the SD card out, then inserted after on and then used Lido...and it somehow worked. I can't explain what sort of voodoo made it go...but now it works fine.
Share this post
Link to post
Still no success. :sadmac:
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
