Jump to content
Forums
  1. Important Information
    1. The 68kMLA Forum Rules   (10405 visits to this link)
      To quote vintage Apple manuals: "Read Me First!"
  2. Community Connections
    1. General 68kMLA News & Stuff
      3981
      posts
    2. Conquests
      40029
      posts
    3. Trading Post
      54452
      posts
  3. Projects & Hosted Forums
    1. RetroChallenge
      http://retrochallenge.org/
      1490
      posts
    2. 68kMLA Wiki
      The creation and maintenance of the 68kMLA's information repository.
      http://68kmla.org/wiki/
      549
      posts
  4. 68k Model Forums
    1. Compact Mac
      Macintosh, 512k, SE, etc.
      47327
      posts
    2. Mac II, Quadra & Centris
      13605
      posts
    3. 68k LC & Performa
      Ah, the consumer computers!
      8278
      posts
    4. 68k PowerBook
      10266
      posts
  5. PowerPC Model Forums
    1. NuBus Power Mac, LC & Performa
      2715
      posts
    2. PCI Power Mac & Performa
      6004
      posts
    3. G3/G4/G5 Power Mac, iMac & eMac
      13821
      posts
    4. PPC PowerBook & iBook
      9107
      posts
  6. Everything Else…
    1. Apple I, ][, /// & Lisa
      7495
      posts
    2. Newton
      1074
      posts
    3. Software
      17653
      posts
    4. Hacks & Development
      19687
      posts
    5. Peripherals
      14930
      posts
  • Posts
    • I really wish we had replacement injection-moulded cases for the 520/550/575. 'Just went to investigate this and broke the only non-broken clip on the I/O cover.   Anyway, my 550 is missing those screws, so I haven't confirmed this yet, but let's see what we can figure out.   According to the Macintosh Computers Service Guide, Volume III (July 1994), page 108, there's two screw sizes used for the rear housing, but no indication of which one is used for what. (Not even how many of each one is used.) One is part number 426-1007, which a cursory Google search seems to indicate as the part number used for the I/O port, but I have some misgivings about that being the correct screw size.   The notation on that page is a little screwy (pun 100% intended), but comparing that part number to its occurrence on other computers in the service guide would indicate a zinc self-tapping pan-headed Torx screw with a 4.22mm diameter, 1.41mm pitch, and 16mm length. The self-tapping part really sticks out to me, as the 5 main rear housing screws just screw into plastic, so I could see them using self-tapping screws in the factory to tap out those holes. Also, measuring one of the main rear housing screws with my calliper, I get a 4.2mm diameter and 16mm length. The screw I pulled doesn't look self-tapping, and has a cheese head rather than pan head, but otherwise seems to fit the bill pretty nicely as 426-1007. (Also, 4.22mm? That's a weird diameter. I wonder if maybe 426-1007 isn't actually a metric screw.)   The other thing that makes me think that 426-1007 isn't the correct part number is that I can confirm that the I/O cover's screw holes are a smaller diameter than the 5 main screws on the rear housing, and the hole looks like it was meant for a machine screw. (Maybe I should have led with that?) The other screw listed on the page (part number 410-1308) is an M3x5.8mm screw, which is of course a smaller diameter than 4.22mm. (I can't tell by looking in the hole below the I/O cover if it's fine or coarse pitch, so could be either 0.5mm or 0.35mm.) So I think that's the one. Now, what kind of head does it have? No idea. I can't find any photos of the I/O cover's screws, but the installation instructions for the Sonnet Presto Plus seem to indicate that it's a Philips. (But the photos are really low-res.) If anybody has any of those screws and could take a photo, that would be helpful.   I'll see about taking a trip to the hardware store tomorrow to try and get to the bottom of this, but I'm also expecting an Xserve to be delivered tomorrow, so I may have to put it off until Tuesday.
    • Hey guys, let me try and narrow this down. I’ve been looking at the models suggested here and it’s a hard choice so here are my requirements:   1. I run mainly OS8.6 across all my systems. It would be nice to access it from a newer OS occasionally but 8.6 is pretty much what I run.   2. TCP printing seems the better way to go since all of my systems can print to it, but as a bonus it would be nice to have a serial port. If not, no worries.   3. I want a color laser jet.   4. I also don’t care if it’s big and bulky.   5. I’ll buy used, and if possible keep it under $200.   What are my options then?
    • After reading the thread a couple times, I’m... overwhelmed. lots of options and lots to think about.   i think I wanna do it ‘right’ the first time around and get a color laser jet with an Ethernet card in it for network printing. It makes more sense for network printing since I’ve got multiple machines around in different rooms.   My main OS is 8.6 across all my systems. Sometimes I boot into 7.6.1 but rarely, so I’d need something that’s color, a laser jet, and has an Ethernet port. I’ve always disabled all the printing extensions in 8.6 since I never use them, so I’m gonna have to figure out how to connect to the printer (desktop printer utility in the extras folder?) as well as figure out which driver to select for it.   But that’s after I figure out which printer to buy in the first place.
    • The capacitor itself looks fine and there’s no direct shorts to ground anywhere, I’ll switch it around and see if everything is okay, I still need to get a new power supply, but does anyone know what C21 does?
    • Yes, there is a chance. I saw someone replace a tantalum cap backwards a few times and blow it each time - did work after they realized it was backwards.
