Jump to content
Sign in to follow this
flowers
MAC VIDEO ADAPTER - 1988
Recommended Posts
Hello!
 I've the hands over a Macintosh SE/30  that got inside a " MAC VIDEO ADAPTER" with an exit by 8 DIN Plug. IS anybody here that know more about it and/or can let me know the pinout of this Exit ?
 The adapter is a simple PCB that manage and transfer signals from the logic board to this 8 DIN pin, with true it the 14pin power connector. If needed i can post some pictures. There are 7 pins connected with just one out ( the nr. 7).
Edited by flowers
Share this post
Link to post
Share on other sites
Yes sure.. here a first picture ^_^...  is true that i can check where the adaptor is taking the signal in the macintosh plug.. but if anyone have Information  about this adapter is welcome...
Edited by flowers
to let the picture be seen in the post directly
Share this post
Link to post
Old school setup for hooking ti a projector generally. To the best of my knowledge there aren't any monitors that'll sync - more or less just late 80s/early 90s projectors (the suitcase sized ones).
Share this post
Link to post
hmm...  but curious is to see what is the video signal exing from it..  is it a composite video or a separated "Chroma/Luma"... just curiosity...
I remember the 80/90 projectors but i didn't remember in that a PLUG IN 8 DIN...  something much more familiar with some old black&White TV...  but again. i'm just looking to understand what signal are coming out from the 8DIN.
Edited by flowers
Share this post
Link to post
Gotta be Black and White for TV input if there's no PDS Card involved. VERY strange, does the board plug into the A/B connector to pass the signals through to the neck board? I'm guessing there's an external box powered by the connector? That would convert the Mac video fed to the connector to convert the  output to NTSC a/o PAL a/o Composite. You'll need to buzz the connections to see what's going on.
Share this post
Link to post
Didn't think that was right, the connectors on either side are too wide to plug into any connector of the SE/30. Are they single row ii-pin or a double row? What IC is hiding behind the ferrite ring?
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
