Jump to content
el_jeffe
Mac Plus Floppy Drive - should I replace it?
Recommended Posts
Was having a discussion with a coworker about floppies on vintage computers. He suggested I probably shouldn't bother replacing the floppy drive at all since there are all sorts of solid-state card devices out there now. I just feel like my Mac Plus won't be fully 'restored' until it gets a working floppy drive.  No reason I can't have both but it does make me wonder if the floppy drive is really needed.
Share this post
Link to post
Share on other sites
If you ever have a need to dump and preserve floppies as Disk Copy 4.2 images, you will absolutely want to have one.
Generally I agree with the sentiment that floppies should be used sparingly. There's limited quantities of them out there, and they're all living on borrowed time.
Share this post
Link to post
I agree that a computer doesn't feel completely restored without a working floppy drive.  I have a Mac SE that I restored from multiple machines, yet was frustrated by the lack of a functional floppy drive.  Tried cleaning and lubricating one or two drives without success.  Maybe three; I don't remember anymore.  Finally bought a working one (from LaPorta I believe) so that I could finally have a fully functional machine.  (Of course, now it may be having SCSI problems but that's a separate issue. . .)
I have a Floppy Emu for it, so a floppy drive isn't absolutely necessary but it just doesn't feel like it's a fully functional computer without it.
I will primarily use the Floppy Emu with it, but it's nice to know there's a working floppy drive in there should I ever need it.
Share this post
Link to post
1 minute ago, LaPorta said:
You know, if you ever don't need those other 800ks... ;)
I'm sure I will need them, especially if the three Mac Pluses I mentioned in another thread all turn out to have defective floppy drives.  But, I may have to pay you to fix them for me at some point. ;)
Share this post
Link to post
A slight aside, but how much should we tear down a Mac Floppy drive when deep cleaning/lubing?  I’m working on my first (Mac Plus) and I currently have a seriously dirty drive in 3 parts—the disk sled assembly, the main board/head/spindle lower unit, and the eject motor/gear assembly.
Should I be tearing it down any further or stop here?
Share this post
Link to post
You don't need to tear it down further; in fact all you really need to do for lubrication is remove the top "disk sled" along with the other sled on the bottom. Just don't try disassembling the head/stepper motor assembly because you'll probably mess up the alignment.
Share this post
Link to post
OK, thanks.  I went ahead and took off the eject gear assembly because I ordered a replacement gear for the fragile one.
Share this post
Link to post
Speaking of, can these drives be repaired if they're out of alignment or have other issues? Mine has a broken eject gear but it also does not read disks even after cleaning and lube. Wondering if it's just cheaper to replace it.
Share this post
Link to post
That can be a few things. Could be the drive heads making insufficient contact. Could be head alignment. There is a procedure for doing it with a few instruments in the Pina books.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
