Jump to content
trag
Macintosh IIvx, Detailed Scan/Image?
Recommended Posts
I am looking for a detailed (good enough to read chip markings) image of a Mac IIvx motherboard.   Images of the P600 and IIvi will not do, as it is precisely the differences, I want to see.
Specifically, I'm interested in the corner/edge of the board where the Cache and Tag RAM chips are located, and possibly the underside of the same region.   I would like to know what parts Apple used for the cache SRAM and Tag SRAM.  Also, there are a number of empty resistor positions in the region on the Performa 600, that I suspect are populated on the IIvx.
The Tag RAM will be the difficult component to locate, but there's a seller on Ebay who has tubes of 30 chips which are probably the proper Tag for sale.  But I'm not sure.  I'd rather confirm it before I spend the money.
Share this post
Link to post
Share on other sites
Excellent, gpbonneau, thank you!   On magnified view I can make out the tag RAMs and they are ATT7C17, which is exactly what is available on Ebay at the moment.  The SRAMs are less critical as the pinout for those is a JEDEC standard, so any fast enough 8K X 8 SRAM in the 28 pin SOJ package should work.
I couldn't remember when I posted, but it turns out the resistors I'm curious about are on the back of the board.   Anyone have a detailed scan/photo of the back of a IIvx, specifically of the region which is the lower left hand corner in gpbonneau's photos?
Share this post
Link to post
The back of the first MB :
Share this post
Link to post
Thank you again, gpbonneau!   IIRC R125 and R124 are unpopulated on the P600.  So if I add the SRAM chips needed for the cache, I'll need to populate those resistor positions as well.   There might have been a couple of others, but I can use that photo to identify them.
Share this post
Link to post
1 hour ago, AlpineRaven said:
Interested to see the end results!
Looks like there won't be any.  At least not for a while, absent luck.  The four lots of 30 chips of the TAG SRAM sold before I got back to them today.   I would not have expected there to be much demand for them.    Ah, well.   Making a P600 slightly better is fun, but not Earth shattering.
Share this post
Link to post
Some Cache DIMMs for the Nubus PowerMacs used chips that will do the job. The TAGRAM as well as the SRAM will fit.
Share this post
Link to post
Thanks, Bolle.  That's good to know.   Looking at how difficult it can be to find old TAG RAMs, I wish I had bought one of those lots of 500 L2 caches from OWC, back when.  I forget what they were asking -- something like $125, or $.25 each, IIRC.   I could never think of a reason why the expense was worth it at the time.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
