Jump to content
WakelessFoil
MacTCP Networking
Recommended Posts
I recently got my Macintosh Plus working with all 4 MB of ram. I have an Asante EN/SC Ethernet to SCSI adapter and want to put it to some use. I hooked up everything and downloaded the EN/SC EtherTalk software along with AppleTalk 57.0.4. Installed it on system 7.1 and also got MacTCP 2.1. I made sure to hook the adapter to a 10base-T only hub so it wouldn’t get confused with 10/100. I tried to configure the TCP/IP settings but I don’t think it’s making a connection at all. MacWeb won’t connect or load it just spits out an error code as if the machine was connected to nothing.
Here is a post from someone who had success with a similar setup: http://lowendmac.com/rivera/05/1129.html
any help and/or advice is greatly appreciated!
Below are some images of my TCP control panel as well as a hardware diagram.
Edited by WakelessFoil
Share this post
Link to post
Share on other sites
I think your DNS stuff is wrong. Try this:
  • 192.168.0.1, default selected
  • 1.1.1.1
  • 1.0.0.1
The Domain column doesn't matter, the dot that you have in there is fine although I usually call them "dns1", dns2", etc.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
