Jump to content
traildog64
Link Mac SE with MacMini via AppleTalk?
Recommended Posts
Greetings. I'm just starting to learn about classic macs, so bear with me. I have a Mac SE with SuperDrive, a PowerBook G3 Lombard with USB, and a modern MacMini. I'd like to download files from the internet on my MacMini (running High Sierra) to my Mac SE. I get that my Mini can't write in the HFS format. What if I use my G3 as a bridge? Could I transfer images from my Mini to my G3 (Mac OS 9.0), to my SE (System 6.08) via AppleTalk? Any advice would be appreciated.
Share this post
Link to post
Share on other sites
A Macintosh SE SuperDrive (I have a Macintosh SE FDHD, which I believe is identical just with a different name) is a GREAT compact Macintosh to start on! That 1.44mb floppy drive will be a HUGE help. Getting files to and from the Macintosh SE is still a bit of a challenge, despite the helpful SuperDrive.
From your modern Mac Mini, there's basically one way to write files to floppy disks: images with "dd". Here's the list of commands that you'll run to write both .img and .dsk files to a floppy disk. First, see what disks are available:
diskutil list
Once you've identified which disk is your floppy, unmount it (where your floppy drive is /dev/disk2:
diskutil unmountdisk /dev/disk2
Now, DD the .img or .dsk to the floppy disk:
sudo dd if=the_disk_image.dsk of=/dev/disk2 bs=84 skip=1
If that doesn't seem to work, do it again without the "skip" option (and if someone can tell me why that would be awesome):
Now not everything you need to use will come as a .dsk or .img. You will see a lot of .sit files, and in that case, I would download them to the G3 and unpack them directly to an HFS floppy disk with StuffIt Expander. That should preserve resource forks and stuff for when you shove the disk into your Macintosh SE.
...or, maybe you knew all of that and that does not help at all. I hope it does. As for AppleTalk, I'm REALLY curious to see what people say about it. Hopeful that file transfer is possible with it.
Share this post
Link to post
"The Definitive Guide to Connecting Your SE/30" covers all of this extremely thoroughly. We have a sticked topic for it up above the Compact Mac forum.
http://www.applefool.com/se30/
Check "Apple Filing Protocol Ethernet Networks" to start, because it's AFP that won't fool with your resource forks and plays nice with Macs. AppleShare 2.0.1 also has its own section under "More Info" for System 6 users that want to have their System 6 machines act as hosts for file sharing.
System 7 comes with some simple capabilities for lightweight file sharing and hosting without installing extra software, which is also covered in the guide above under MacTCP (before 7.5.3) and OpenTransport (post 7.5.3) within the "System 6 through Mac OS 9.2.2 Setup" section of AFP Ethernet Networks.
Edited by nglevin
links links links
Share this post
Link to post
Yes. I don't believe that your Mac SE would be able to mount an AppleShare volume hosted on the Mac mini, but you should be able to go from the Power Mac G3 to the Mac SE with no problem.
Share this post
Link to post
Hi PotatoFi,
I am not experienced in using Terminal in Mac OS, but I typed in exactly what you said. I downloaded a file image from Macintosh Repository. The name of the file is "BattleChess_1_0_2.dsk"; it's located in my Downloads folder. Every time I attempt it, it says the file can't be found.  I have the USB floppy plugged into my MacMini.
Thanks.
Share this post
Link to post
Probably beyond the scope of what I can mash I on my phone, but look up how to list (ls) and change directory (cd). You probably just need to run "cd Downloads" to change to the Downloads directory, and then run "ls" to list the contents of the current directory. It seems cryptic at first but it's very easy with a tiny bit of practice.
Share this post
Link to post
Hi Dog Cow,
is there any info on how you use file sharing on old macintoshs? As I’m wanting to share my se/30 with my PowerPc and g3 iMac which i have networked.
neal
Share this post
Link to post
3 hours ago, SE30_Neal said:
Hi Dog Cow,
The instructions on this page for Classic Mac Networking are extremely long and comprehensive, and it's worth reading. I also have a couple of Mac books from the mid-1990s, like Macintosh Secrets, which have networking chapters.
If you enable File Sharing on your iMac G3, your Mac SE/30 should have no trouble connecting to it. But you will need an Ethernet card in your SE/30, or you will need another Macintosh, such as a Macintosh LC (this is what I used) or a Macintosh Quadra, which has both LocalTalk and Ethernet ports. This Macintosh will run LocalTalk bridge, and it connects your Mac SE/30 to the iMac G3, from LocalTalk to EtherTalk.
Regarding the original poster's configuration:
As the Mac mini is running OS X High Sierra, that's trickier, as that version of OS X does not have Apple Filing Protocol, so you can't easily use AppleShare between it and your Power Mac G3. Netatalk will add AppleShare back to the Mac mini so you can host an AppleShare server on your Mac mini and mount it on the G3.
With the afore-mentioned Macintosh running LocalTalk bridge, you may be able to get the AppleShare volume on the Mac mini to appear in the Chooser on the Mac SE/30.
Edited by Dog Cow
Share this post
Link to post
Hi Dog Cow,
sorry to hoodwink this tread, yes i have networked and internet ready se/30, PowerPc and iMac on my home network all with sharing on and still can’t get them to see each other. That said ive never networked old macs so its probably me doing something stupid in my nievity? Any ideas.
neal
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
