Jump to content
Sign in to follow this
uniserver
Macintosh Plus Internal Hard Drive *Mod*
Recommended Posts
They're available from an Amiga oriented site (IIRC) that somebody linked to as a source for a SCSI interface PCMCIA and Chiplet Reader Box . . . hrmmm . . .
< scampers off to search bookmarks for "SCSI" heh! [:D]]'> >
http://a4000t.com/store/index.php?main_page=product_info&products_id=180
SCSI Chip $15
Gotta find a Datasheet to check it against the devil we know, though. :beige:
Share this post
Link to post
Share on other sites
8-oWoooo . . . and here I thought I was quite a bit more impatient than the average hacker! You win! ;)
I'm surprised you're even getting as far as :?: in the boot process after that impromptu organectomy!
Sounds like you may have been hit by a random static discharge incident while playing with the toys? How careful were you about avoiding that. I pretty much ignore the possibility other than grabbing everything by a plastic connector or mounting point attached to the ground plane as a matter of habit.
I ALWAYS have skin contact between the hand/wrist/arm that touches the card and the chassis or PSU case during swapouts.
I've got a galvanized steel pan set up as my soldering workstation, but I haven't got around to grounding everything properly or connecting the wrist strap that's still in the envelope.
Share this post
Link to post
Well mcdermd and I were talking about de-grading this machine back to its original 128k glory anyways.
now seems like a good time to get on it :)
I'm still angry this plus board is screwed, but oh well. My normal success rate when fixing/moding things is extremely high.
Share this post
Link to post
Yeah, if I was a Mac at Uniserver's house going to be opened up, I would be scared. :I
Here's another config example that could work if there is room. You would still need to desolder the chip and install a socket though unless you can reach the back pins that need a connection.ardw-img_0351.jpg.bef0288c38d59971f87c621a89632466.jpg
Share this post
Link to post
I get farther then that,
I put the 6.0.8 disk in ,,, it starts to boot
it says Welcome to macintosh, and starts to load i can hear floppy disk access, but then it stops after about 4 seconds, and nothing. sits there.
Any idea what is causing it? originally i thought i was a bad scsi chip that was why i saw'd it out.
or do i have to take the board out back and pump a couple buck shots into it ? :-D that'd be more fun!
Share this post
Link to post
Hope this helps. Just slided the board to get slighly better shot out of it. It's tight packed with power connector, hdd power connector and the opened up scsi cable with the leads soldered on the chip. Would be risky to pull the whole board out. If you want higher resolution picture, PM me.is mi
Edit: Aww.. might need to take another one, difficult to see where the stripes of scsi wiring goes! :disapprove:
Share this post
Link to post
Ok, finally.. Here are better pictures. That is quite a tricky to open up, those cut-wires are bit in a tight fit from the board to connector. Not much space around. Hope these provide any help. If you need original 18Mpix images, PM me with email address.
Share this post
Link to post
I'm real close to giving this another try!
After doing all these Macintosh Portable HD cables… I now know, and understand the grounding situation a little better !!! :-)
Also i am still going to use a external PSU to power the hard drive,
I have 2 12v pie fans I am going to mount, those will also be powered from the external psu.
Share this post
Link to post
You could tap into the A/B's AC in port (just past the switch) and run everything off one cord (and have it switch on and off with the machine as a bonus).
Also, an uninformed person would never know it's been upgraded, because there wouldn't be any outward signs of it.
c
Share this post
Link to post
Yes, and you didnt read my first post of this thread.
10 Oct 2012, 13:15
i've already done this hack to my Macintosh Classic, because i am to lazy to replace the analogue board,
the analogue board was not making enough power to spin up the hd, so i added my own,
Share this post
Link to post
On 11/30/2012 at 2:17 AM, Trash80toHP_Mini said:
K.I.S.S. live by it!
Fixed the boo-boo & didn't stop . . . |)
I think it's laid out, but I'll need to review it when I'm relatively conscious again . . .
I need to "cut the corner" on lines DB1-DB7 to keep those traces as close to the length of the DB0 trace as possible.
No biggie, but I'd appreciate some feedback on accuracy of the pinouts and trace routing aforehand, gang. TIA.
I've got six jumper wires (yellow pads) designed in to lengthen the signals bunched up in the center . . . makes it better . . . and easier . . .
. . . and they're ALL hidden underneath the socketed SCSI Controller IC. [:D]]'>
zzzzzzzzzzzzzzzzzzzzzzzzzzz xx(
wait why is RST on the wrong side of NRC 5380
Share this post
Link to post
Booboo probably, I was asking for feedback like this on the layout way back then. In the meantime, someone (Alaska?) developed and was selling a proven design. Dunno how my design stacks up on the kluge scale by comparison, likely much worse as this graphic was a feasibility study in terms of form factor.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
