Jump to content
Forums
  1. Important Information
    1. The 68kMLA Forum Rules   (10258 visits to this link)
      To quote vintage Apple manuals: "Read Me First!"
  2. Community Connections
    1. General 68kMLA News & Stuff
      3975
      posts
    2. Conquests
      39766
      posts
    3. Trading Post
      53648
      posts
      • ttb
  3. Projects & Hosted Forums
    1. RetroChallenge
      http://retrochallenge.org/
      1490
      posts
    2. 68kMLA Wiki
      The creation and maintenance of the 68kMLA's information repository.
      http://68kmla.org/wiki/
      514
      posts
  4. 68k Model Forums
    1. Compact Mac
      Macintosh, 512k, SE, etc.
      46670
      posts
    2. Mac II, Quadra & Centris
      13345
      posts
    3. 68k LC & Performa
      Ah, the consumer computers!
      8024
      posts
    4. 68k PowerBook
      9981
      posts
  5. PowerPC Model Forums
    1. NuBus Power Mac, LC & Performa
      2693
      posts
    2. PCI Power Mac & Performa
      5929
      posts
    3. G3/G4/G5 Power Mac, iMac & eMac
      13780
      posts
    4. PPC PowerBook & iBook
      9007
      posts
  6. Everything Else…
    1. Apple I, ][, /// & Lisa
      7424
      posts
    2. Newton
      1074
      posts
    3. Software
      17552
      posts
    4. Hacks & Development
      18994
      posts
    5. Peripherals
      14682
      posts
  • Posts
    • A few days ago I got a good deal on a non working M5120 Macintosh Portable. I recapped it and it works fine except for the floppy and the hard drive. I think the floppy drive may have dirty heads or something, because mechanically it seems to work, but can't read or initialize any disc.   I had a strange issue with the hard drive. It was stuck at first, but after insisting on it a few times it finally started spinning and I even could recover the data from it. The owner rejected the data, so I went to wipe it. And here began my problems. Initializing it with Apple SC Utility failed, so I began using Micronet Utility. I couldn't format either, so I began to look for bad sectors and it resulted it had a LOT of them. So I was reassigning bad sectors with Micronet, but it was getting late so I turned it off and went to sleep. The surprise was next morning when the hard drive is somehow freezing the computer right after the boot chime. It just gets to the gray background with the mouse at top left corner. Sometimes enters in a chime loop. It won't even boot from floppy or from an external hard drive, unless I set the external drive to SCSI 0. This way I can boot the computer, but the internal drive won't show up on Micronet because SCSI 0 is being used by the external drive.   I'm 100% sure it's the hard drive causing the problem because I have another Portable M5126 and:   1. M5120 works fine with M5126 hard drive 2. M5126 also freezes the same way with the M5120 hard drive   I know I can look for another Portable Drive or buy a SCSI2SD, but I though I could get this drive running again, and it bothers me. Also my plan was to fix it and resale, so I don't want spend a lot on it. If anyone can give me some advice I'll appreciate it.   Thank you very much!
    • Just came upon this thread. Thank you all for your valuable input and advice.  I have 64MB of RAM on order from OWC, along with a ROMinator II that's on my desk waiting to be installed. I'll report back once everything's installed.
    • Congratulations! Glad you were able to get your Mac SE/30 fully operational!
    • Finally I got RAM bank 2 working on my SE/30. Lesson learned: replace ALL F258s, not just those that look damaged.   And maybe more exciting, we now have 256 colors. I was happy to discover that the Mac had a Radius Color card installed when I bought it. Unfortunately, the card turned out to have too little VRAM to display more than 4 shades of gray. So I bought a number of NOS ZIP VRAM and put in the card, and now: 8-bit color!   So finally I can play those old Sierra AGI games in color! Those games were my favorites when I was a kid and had a Mac Classic. Of course I wanted to play them in color, and I was so disappointed when it later (on my Performa 460) turned out that they can only be played on old Macintosh II models (pre the 32 bit clean ROM). Or an SE/30 (with the dirty ROM) + a color card. And here we are!   (For some reason Kings Quest I and Space Quest I still only works in B/W. But the rest works fine in 16 color)
    • As a 1400 and Duo fan I find this very interesting. I'd thought the name sounded French, but apparently it's based on veräussern: German for divest or dispose of? Tried different combinations using "dispose" of PowerBook display and hit on this 2005 article:   https://lifehacker.com/how-to-use-your-powerbook-with-the-display-closed-109130   I'm wondering if the ADB KBD you're using might do the same kind of magic described for bumping the author's 12" PowerBook into external display only mode using a USB KMD? Might be worth some tinkering? IIRC "Clamshell Mode" was introduced with the Pismo and dedicated all VRAM to the external display rather than splitting it between screen and external display. IIRC I was running at 1600x01200 in 24bit? That one required closing the lid at some point during startup, which also might be worth a try on your 1400. Instructions are available in the Pismo user manual.   I'm thinking a hack of the Monitors control panel to deselect the internal display in some case specific manner might be possible given today's disassembly tools?
