Jump to content
Sign in to follow this
Language card question
Recommended Posts
Does the language card should be configured in order to work properly ?
I ask because i had two Apple II europlus at home, one did not worked (showing only square blocks on the screen) while the other worked fine, using the working one to troubleshoot the other, i removed the language card from the working one and swapped it and get it working, but the other one also worked without the card and single ram instead...
Share this post
Link to post
Share on other sites
Create an account
Register a new account
Sign in
Sign In Now
