Jump to content
MacinPosh
Mac SE - Third of screen blurry/lines on screen
Recommended Posts
I recently bought and repaired a Mac SE - but whenever it boots, about a third of the screen is blurry. I assumed it was a logic board problem, but testing both the SE board in an SE/30 (which worked fine) and the SE/30 board in the SE (which produced the lines) revealed that it's actually an analog board issue. I've already replaced any leaky caps to no avail.
Any ideas?
Share this post
Link to post
Share on other sites
Looks like the centering rings have been knocked, since the cursor image is backwards. Might be worth giving them (and the h/v size) adjustments a twiddle.
Remember your gloves! (Damn CRTs...)
Share this post
Link to post
To clarify Techknight's answer - the problem is on the Analog Board. Like he said, it is either the Width Coil or the cap next to it.
In adding, sometimes somebody turns the width coil too much of too hard and the ferrite core pops out or breaks. Many times somebody will use a screwdriver on it and that will shatter the ferrite core giving you such a problem like this. DO NOT USE A SCREW DRIVER! GET PLASTIC "TV TUNING" TOOLS TO TURN THAT COIL!
Share this post
Link to post
I've tried replacing the 3.9uF Cap and adjusting the width coil, but there's no improvement. It just pushes the problem left and right across the screen.
Any other ideas?
Share this post
Link to post
CENTERING THE SCREEN QUESTION:
The visible display has moved to the left of the screen area, but I don't see any adjustments for this anywhere. I know how to take the case off, and I can see all the adjustments, but no adjusting moves the display back to the center.
Should any of the visible adjustments (four pots) make the display move back to the center? If so, which one?
ANSWER 1: No. This extremely dangerous operation is accomplished by rotating the two metal rings on the back of the CRT. These rings are usually glued together and they move the image diagonally. By adjusting the two diagonals one can achieve the desired position.
The rings will need to move separately in order to adjust them, so the dab of paint that glues them together will need to be cracked (this can usually be accomplished by just rotating the rings, but sometimes they will have to be gently pried apart). Let me repeat this is a very dangerous adjustment as it is impossible to do with the machine off and the tabs on the rings are within millimetres of 9k volts. The preferred method is to rotate the rings with a non-conductive probe (laymen call these unsharpened pencils or plastic pen barrels.
ANSWER 2: I don't think any of the 4 pots are going to accomplish what you're wanting. There's also an adjustment on the yoke of the CRT, just in front of the small video board that plugs into the back of the CRT. If you look closely there should be a small lever/arm that you can move. As you move this, the alignment of your CRT video should also move right/left. Since this area is right in the middle of some high voltage and has to be done with the system/CRT on, it's not exactly something for the faint of heart or inexperienced to attempt.
Try Answer 1 but be careful! Even if you adjust the rings so you end up with the screen higher than "normal" you can lower it with the pot on the analog board.
Edited by Elfen
Share this post
Link to post
I think Alladds is right since the display is both to the left and down. Twisting them slightly will bring it up and to the right. Then adjust as needed with the pots and core.
Sorry Alladds, I did not read your post and missed it altogether.
Share this post
Link to post
Found this post about adjusting the magnets to fix some screen issues elsewhere (indeed, I stumbled into the 68kmla Flickr site - no action in 3 years! - probably more a reflection of Flickr than 68kmla!). While this may not impact the foldover of the image on the monitor, it might help fix the screen's display which appears to be slightly tilted downward to the right, at the bottom edge. Anyone up for some magnet tweaking!
https://www.flickr.com/photos/66071596@N00/2304506276/in/photostream/
SE/30 Magnets on Yoke
Four magnets can be seen in this photo (there are 8 total), protruding tips painted in pink, surrounding the CRT yoke. Twisting these magnets alters the screen shape. When twisted clockwise, the topmost center magnet elevates the top-left section of the screen and shifts down the top-right section of the screen. After adjusting one magnet you will likely have to adjust others to make the screen alignment look correct. Special thanks to Tom Lee for the tip on adjusting these magnets to resolve screen distortion problems.
Edited by TimHD
Share this post
Link to post
It's not those Magnets, TimHD unless a couple of them are missing from the yoke. Its the position of the yoke and magnet assembly and that is controlled by the rings. Twisting those magnet will distort the screen as they are set to keep it in its square shape.
A picture of the section by MacinPosh would be great.
Share this post
Link to post
The problem is definitely foldover, and the reason is that, for whatever reason, the horizontal retrace is happening too slowly. The retrace speed is determined by the inductance of the yoke, capacitor C12, and the inductance/capacitance of the flyback transformer.
The yoke is probably fine since the rest of the picture looks fine, so concentrate on the other two. Of those, the flyback is the more likely failure but C12 is easier to replace, so start with that. :) It should be 0.033uF (maybe slightly different on some models), and I would use a part rated at 250V, or more if it's labelled that way on the part you're replacing.
What normally happens is that when a line of video finishes, the HSYNC pulse goes low and transistor Q2 switches off. At that point, the beam is at the right-hand side of the screen and there's several amps of current going through the yoke. When Q2 turns off, that current charges up capacitor C12, in the process moving the beam back to the left side of the screen for the next line. That whole process is supposed to finish well before the next video line starts, but if C12 (or the parasitic capacitance of the flyback) is too large, the retrace will happen too slowly and the next line of video will start before the retrace has finished.
It shouldn't be related to the positioning of the yoke or the magnets. There are a few other possible failure points on the analog board but C12 and the flyback seem like the most likely.
Share this post
Link to post
I am thinking flyback, its probably on its way out.
Except that's foldover we're seeing, so it's a horizontal issue.
Regarding the centering magnets, if they show no indication of being disturbed in the last....I dunno 25 years? Don't bother touching them. The rotation of the screen is more the yoke itself shifted at some point but that shouldn't really affect the horizontal deflection that badly. That's a solid indication that something about the horizontal deflection circuit is faulty. Verify your adjustments with the horizontal centering and width coils.
Edited by CelGen
Share this post
Link to post
Thanks for all the replies. I've tried replacing C12 (with some caps that I accidentally ordered, but happened to be the correct value), and I've given the coils more adjustments to no avail. I'm sure that the yoke isn't the problem, as I've tested the analog board in another machine with and it still produces the lines. Is it worth me ordering a replacement flyback to see if that fixes the issue? Unless someone happens to have a spare they don't need?
Share this post
Link to post
Chasing a wild goose here...
Get some cloth measuring tape (like from a sewing kit) and measure that floppy disk icon.
Why? OK, hear me out.
- The Mac's resolution is supposed to be 1/72nd of an inch per pixel.
- That Flashing Disk Icon is 32 X 32 pixels. This would make the icon (doing the math...) .444th inches or 4/9th inches (just a tiny bit over 7/16th inches) square.
- If it not a bit over 7/16th inches square, you need to adjust the screen's height and width before adjusting its horizontal/vertical position. This is done at a couple of pots near the horizontal & vertical adjustment area.
If the screen is too wide, shrinking its width will lessen the fold over. After that you can adjust the horizontal position. The screen's width can be set to near maximum that it will fold over and no matter how you adjust the horizontal position it will never unfold.
There were a coupe of recent discussions about the height width of a 68K's screen. One of the links is here:
https://68kmla.org/forums/index.php?/topic/27020-se30-with-a-smaller-screen/?p=288235
But for you, you need to shrink the screen first, then adjust its position and then when the fold-over issue is gone, do tiny adjustments until it is right.
Share this post
Link to post
Q: When you adjust the horizontal coil, does the ferrous core rise and lower when you turn it?
If it does not, the threads inside the coil could be stripped. That can be a problem within itself and no adjustments can be made until it is fixed.
Share this post
Link to post
It's probably the flyback then (which is an integral part of the horizontal circuit). If you have two machines, you could try swapping flybacks before finding a new one.
Do you have access to a scope? There are a few signals which could tell you what's going on.
Otherwise, another idea is to turn the brightness all the way up so you can see the scan lines. If the scan lines extend off the right side of the screen, then the problem might not be with the length of retrace but with its timing (starting too late), which would indicate a problem with the circuits driving Q2.
Share this post
Link to post
Thanks Elfen and apm for the next suggestions. I'll try making those screen adjustments incrementally and see if it helps. The ferrite core does move and there is a noticeable change in the image width, but the lines just move with the picture as the width increases/decreases. I don't have a spare flyback I can try out, but I do have an analog scope to take measurements with.
Share this post
Link to post
OK then, if your scope probe is rated to 200V or more (probably true if it is a 10:1 probe) then you can measure the voltage on C12.  Careful though as a couple points on the analog board sit around 800V -- take the usual high-voltage precautions. You might even wire up the probe to C12 with the power off, and then switch the machine on. Attach the scope probe's ground clip to one of the ground points on the analog board (I use the metal cage around the flyback). Since the ground clip has to be attached by fingers, that should definitely be done with the machine off.
This measurement is from a working Plus but the circuit is essentially the same:
There should be a ringing pulse of 150-200V at a frequency of 22.25kHz. This is the yoke discharging energy into C12 every retrace cycle. The important part is that the whole pulse should be around 9us long (for comparison, HSYNC is low for 12us -- you can measure this on P4 pin 10 or U1 pin 1). If the pulse on C12 is much longer, then it indicates something wrong with the inductors or capacitors in the horizontal circuit. The flyback serves both functions, so a pulse that's too long is very likely a flyback failure. Other explanations are possible, but the flyback is a known failure point and can fail in all sorts of ways.
If on the other hand, the pulse is the correct length, then try the bright scan lines suggestion from my last post (which will tell you about the timing of HSYNC). If that's wrong, then the probably culprit is in the circuits driving the base of Q2.
The Classic has a horizontal centre control but the SE analog board doesn't. Personally I wouldn't mess with the CRT rings. They can move the picture around a little bit but they can't cause this kind of foldover.
Edited by apm
Share this post
Link to post
I measured the voltage at C12 and did indeed obtain a 9us long pulse. When I swapped out Q2, the foldover width reduced by half so only makes up a small proportion of the screen now. I tried turning up the brightness and the scan lines do extend off the right side, hopefully you can see it in the picture.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
