Jump to content
bibilit
Analog board with Voltage too low then too high
Recommended Posts
I have been busy this week with a Classic II A/B.
Voltages were too low on the first place, so manage to replace the usual caps, but they remain low after the replacement.
On a second try those were far too high (5 volt was 6.25 v and 12 v around 12.2)
Any idea ?
Share this post
Link to post
Share on other sites
Did you adjust it? There should be a potentiometer:
Let's start there...
If you can't get a good result you can try to resolder PP1 and then replace the Optocoupler
Edited by 360alaska
Share this post
Link to post
Update,
Replaced the Optocoupler yesterday, and apart from a first boot when a cap bursted open (i realised i fitted it the wrong side) the AB board is working again.
Some weldings were a bit weak, and after touching those up, voltages are fine ans steady.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
