will a radeon 9200 work in 7600 ?
It'll work in any PCI Mac with OS 9, whether ot not it's worth it depends on the CPU, if you are running a high end Mach5 604e or G3/4 then great, if you are running the stock CPU (up to 200 mhz) then not worth it as the CPU can't offload the data to the GPU fast enough to make any difference.
