There's a lot of chatter online about the aggressive head-parking that WD's low-power drives tend to use. I noticed it myself when I replaced the Toshiba drive in my MacBook with a nice new shiny Scorpio Blue. After cloning my old drive across and booting into it, an hour or so later the Load Cycle Count was at over 140. By comparison the LCC on my PC's system drive (a WD Black) is 21 after 8093 hours.
One fix for OS X is to use hdapm to override the drive's setting. It seems to work, but I'd prefer something that works on the hardware level. Especially as this parking issue probably also affects bootcamp.
There is a WD tool in circulation that allows you to alter the default park time (8 seconds in my case). However it's a dos app. I tried a bunch of different boot disks and finally found that FreeDOS was able to function properly on an Intel Mac. So here's a prebuilt bootable ISO that will allow you to see the current setting on your WD drive and alter it. All the info came from here.
Once you've burned the ISO, boot holding down C. When the disc loads (blue screen) hit enter at the boot prompt. You can now run wdidle3:
wdidle3 /R shows you the current setting for your drive
wdidle3 /D disables the parking on older drives. on newer drives (like mine) it sets it to 62 minutes
wdidle3 /S sets the parking time in seconds (/S300 for example)
