Preliminary research and thoughts:
Inspired by the recent spate of video hacking on compact Macs, EvilTim's MPxPlayer, and of course the Poor Man's Greyscale Project, I'm wondering how to go about converting the CRT and analog board of a compact to a VGA monitor.
Ideally this would be plug and play with later Macs and PCs without requiring software hacks (as used in the MPxPlayer). And unlike the PMGS, I am looking at using the existing a/b and yoke, rather than cannibalizing another monitor.
Yes, I realise this would require extensive modifications, and may turn out to be impractical. I just want to investigate possible approaches to see whether it is remotely feasible.
This would be a step on the road to an LC630 (or similar) in SE hack.
Resolution........................................ 512 x 342 Horizontal scan rate.......................... 22.3KHZ, (4µs on, 40µs off)
Vertical scan rate ............................. 60HZ (180µs on, 16.4ms off)
the video signal is 15.6672 MHz
So at a minimum, I'm looking at the following conversions:The VGA specifications are as follows:
* Selectable 25.175 MHz or 28.322 MHz master clock
* Maximum of 800 horizontal pixels x 600 lines
* Refresh rates at up to 70 Hz
* Vertical blank interrupt
* 0.7 V peak-to-peak
* 75 ohm double-terminated impedance (18.7mA - 13 mW)
Signal
For most common VGA mode 640x480 "60 Hz" non-interlaced the horizontal timings are:
Clock frequency 25.175 MHz
Horizontal pixels 640
Horizontal sync polarity Negative
Total time for each line 31.77 µs
Front porch (A) 0.94 µs
Sync pulse length ( B) 3.77 µs
Back porch © 1.89 µs
Active video (D) 25.17 µs
The vertical timings are:
Vertical lines 480
Vertical sync polarity Negative
Vertical frequency 59.94 Hz
Front porch 0.35 ms
Sync pulse length 0.06 ms
Back porch 1.02 ms
Active video 15.25 ms
640 x 400 @ 70 Hz is video mode used for booting most x86 personal computers.
640 x 480 @ 60 Hz is the default MS-Windows graphics mode with 16 colours.
Code:
Spec Mac VGA Unit x
Clock frequency 15.6672 25.175 MHz 1.61
Resolution: H 512 640 pixels 1.25
: V 342 480 pixels 1.40
Scan Rate : H 22.3 31.476 kHz 1.41
: V 60 59.94 Hz 1
