Using Magneto Optical drives on vintage 68k Macs
Bernoulli had a second generation in the late '80s and early '90s. It co-existed with Zip for a couple years, and got up to 230 meg capacity in a smaller 5.25-inch size. It's hypothetically nearly as reliable as MO because it (as with MO) has an arrangement where the r/w head doesn't touch the physical storage media.
Though, I've found it's impractical to get running at this point.
To the points about DVD and LD - success and popularity are different things and that was my point. LD was a success because it sold loads of copies over 20 years, even though it wasn't more popular, for the cost and convenience reasons you mentioned.
Recognizing this kind of thing is a rampant problem in vintage-anything. We have this discussion once in a while on this very forum even. A lot of people mistake the popularity of Zip as a sign of failure on the part of all the other options in this market, even ones that lasted longer, were popular everywhere else, or found success in specific markets (like MO and medical imaging and archival) (Unfortunately, the devices having found use in those specific markets is probably part of why they're harder to get in the US -- but MO was popular for home and office use in Japan, so Japan and buying/shipping services therein can be a good resource for MO media.
There were a few JDM kits for the blue-white and various Power Mac G4s, but I suspect the more popular options here were to use USB, use Firewire, or add a SCSI card and use that. Unfortunately, I don't know if going and getting one of those is worthwhile per se because they're not ultra-common even in Japan. You have to either know what you're looking for or accident your way into it, which'll be turbo-expensive for people living in North America.
What's your specific use case for the drive in the G4? Is it just making/transferring data (where USB/FW will be fine) or are you looking into making G4-appropriate restore media that'll need to be booted from?
To be honest, I'm tempted to say DVD-R or CD-R based media is better fit for booting a G3/G4, especially since IIRC these machines are often reputed to work fine with newer SATA based optical drives using something like a SIL3112.
Though, like, in general I do know/get that it's nicer to have the drives be internal when you can. In that case, the only thing I can think of is keep looking for different drives that are set up with their connectors where you need them.
Beyond a certain point (uni-north, I believe, is that point) you can boot USB on some newworld systems (iBook and one of the early ish G4s but not the yikes, some later iMac G3s, the pismo, all PowerBook G4s, that kind of thing) and while it is slow it does work so in theory you can just keep a, like, 32-gig USB stick around for restoring those machines as well.
Well, I did some surgery on the drive cage and ripped off the metal backplate that’s 3 inches wide and 1/2 inch high covering the IDE port of my Fujitsu 1.3GB MO. I’ve successfully set it to slave and it’s on the bus with the DVDR drive. I now have, on one single machine:
- SATA Card with 2TB SATA hard drive
- New Apple Original DVDR SuperDrive
- USB Zip 100Mb drive
- Adaptec SCSI Card with:
   - Iomega Jaz 1GB SCSI
- Fujitsu 1.3GB ATAPI MO Drive
I can use this machine to backup and restore from and to any of these media. Additionally it’s connected to my NAS which supports AppleShare, with 16TB of storage space.
The G4 can boot Mac OS 9 or OS X 10.4.11, and download from the internet directly using TenFourFox, or access files I’ve downloaded from my Windows 10 PC to the NAS. All of my CDs are imaged onto the NAS and I can burn a CD, or write the contents of a CD to any one of Zip, Jaz, or MO and use on any one of a Mac SE through the G4 even.
This is the ultimate in bridging. I realize I don’t have a floppy drive. Don’t fret, I’ve got many 68k Macs with floppy drives, I just copy the disk images using another media and access on the Mac I want to make floppies on.
I also have SCSI external Zip, Jaz, CD (and a Yamaha CDR) and MO drives and can easily move data back and forth with great ease.
I’d also get into the other formats but... this is quite enough. 100mb on Zip is a convenient size for the cost (new sealed disks about $1.5-$2 each). MO is great for making installer media and such. Easily rewritable and cost of between $0.003 and $0.008 per megabyte (depending on size used). It seems faster than Zip, but slower than Jaz. Jaz 1GB is great for capacity, speed, and reasonable cost. 3 packs of 1GB cartridges are about $15, or $5 a cartridge. Right in the middle of cost per MB of MO. They’re not as reliable as MO, but they’re freaking fast. Faster than most of my internal hard drives. Faster than SCSI2SD in most of my tests.
On my test bench I have a keyboard and mouse, a monitor, and a stack of Jaz, Zip, and MO external drives all daisy chained. I connect a Mac I want to test or use to the setup and boot whatever media and OS version I want. Last night I played MYST on an LC475, which I copied over to a 640mb MO disk to try. It worked great. That’s my use case. Just moving data and having fun with it at the same time.
You're my hero. That is a fantastic accomplishment. Thanks for posting so many of the specifics, as well as the MO driver that you used.
Thanks for the kind words. I have since added a dual-core 2.3Ghz G5 to the bridging setup, with an ATTO UL5D PCIe SCSI card, which has my 1GB Jaz drive option, and I added a Fujitsu firewire 1.3GB MO drive to the mix.
It allows faster browsing of the vintage software sites, and better downloads. The native SATA on the G5 also helps with compatibility.
I have since learned that an advantage of the MO disks 540mb and under is that they are 512bytes/sector, which affects compatibility on some things. For example, olePigeon has a Jackhammer card, and his magneto optical disks >540mb don’t work because they are 2048bytes/sector and the card doesn’t support it.
On some of my vintage Mac’s, I want to swap out the internal floppy drive for an internal magneto optical drive. Last year when I found out about magneto optical, I bought whatever drives I could so I would have many options.
I had a realization about the stack of Fujitsu 3.5” IDE magneto optical drives that I have.
While I could get the drives to work and format disks, I could not get the drives to boot.
Then it dawned on me this morning: FWB Hard Disk Toolkit supports removable cartridge drives AND IDE drives. The FWB driver for IDE drives supposedly supports both SCSI and IDE devices in a single driver.
Theoretically, I could format an MO disk using FWB HDT 4.5.2 and enable support for ejecting the disk upon unmount, and it should work just like my SCSI MO drives.
When I get time and energy I’ll try it out. If anyone has some insight into this before I try it, I’d love to hear it. I’ve never really used any IDE drives on Mac, besides my G4 Digital Audio, where I just used the Apple drive setup.
Update: FWB HDT could see the drive, but my G3 Mac froze when trying to install the FWB driver to a disk. So I tried booting without the MO extension installed (to avoid any conflicts) and then the FWB Software couldn’t see the IDE MO drive.
However, it was able to see the SCSI MO I have, so I put the target disk into there and tried to install the FWB driver. According to the FWB software, both an ATA/IDE and SCSI driver have successfully been installed to the MO disk. Great! I eject it all and reboot.
The MO disk I want to boot an IDE MO drive has 8.6 successfully copied over to it. However, it does not boot. The drive starts reading the disk on power up, and I can hear disk access, but then the drive light just starts flashing. I get gray screen, movable arrow, but nothing else.
Anyone else have any experience with FWB HDT and removable media ?
Not sure what was preventing it from booting before or what I actually did to change things, but it fully boots now off MO disks on this IDE MO drive.
I did a “physical format” using the MO extension, and it worked for booting. I did not get FWB’s driver to work.
However, the drive boots on my 333mhz beige G3, from 1998, but the same disk and drive won’t boot my 233mhz beige G3 from 1997. I wonder what changed on the IDE bus between those two changes.
Apologies if I am preaching to the choir, but revision A of the beige G3 logic board can't use slave drives, while B can. So I guess there are significant differences to the IDE controller between them...
Yes, but my understanding, based on what little research I've done, is that those differences were mostly in software (the only obvious hardware change between the revisions was the upgrade from Rev. A's Rage II+ to Rage Pro for Rev. B and Rage Pro Turbo for Rev. C).
In other words, the IDE controller is, for all intents and purposes identical across all revisions, but the software that drives it (in the ROM) was improved to allow for slave drives (and presumably to fix software bugs in the IDE controller and elsewhere).
Someone please correct me if I'm wrong!
c
Just for clarity here, I’m running my MO drive in master mode using the jumper on the drive to set that.
If I could get my 1997 G3 to boot with Rev C ROM I could tell you the result but so far it does nothing when swapping the ROM.
c
Thanks for clearing that up, I assumed there were physical hardware differences beyond the gpu...
I have a rev A G3 MT so was aware of the A-B differences, I didn't even know there was a rev C until now!
I’m thinking of getting a 9.1GB 5.25” magneto optical drive and a bunch of disks so I can easily access my software collection with the higher capacity.
I note there are multiple disk formats, specifically 1024 byte per sector, 2048, and 4096.
There’s scant documentation online on these drives. How can I know for sure what drives will work with old 68k Mac’s, and what disks work with what drives? Also, there is some pretty cheap WORM media, how do you write to those using the Mac file system?
Any help is greatly appreciated. I know very little of 5.25” MO.
I haven't run into any issues using the onboard SCSI interface for various sector sizes on my IIci and IIfx. But for the faster FWB SCSI card, it's limited to 512b/sec for some reason. I've been looking at getting a 5.25" drive for quite some times as well. Fortunately when it comes to the 5.25" drives, it appears that most discs come in the 512b/sec variety. The downside is that just like the 3.5" discs, everyone wants the 512b/sec discs. So even at the 5.25" size, expect to pay a huge premium for the 512b discs
I've never used a WORM disc. I don't know how it's written. There must be some sort of special app like Toast or something where you prep all the files, then it writes to it. But I've never seen the software.
Inexpensive WORM discs could be useful for making startup utility discs similar to a CD, or duplicating CD games.
The benefit of making a cheap startup utility disc using a WORM 9.1GB disk would be... the size! Imagine all of the tools, utilities, and images that you could put on 9.1GB volume... That's kind of why I'm wanting to go this route.
Found 9.1GB WORM disks for $4 a piece. I bet you could work out fixed-rate shipping with the seller to avoid the cumulative $8 shipping per disk. There's gotta be software somewhere.
There’s currently a lot of 20 x 9.1GB RW disks for $150 starting bid, ends tomorrow.
What's SCSI DVD on 68k/PPC Macs look like? That'd get you ~9 gigs if you could make and burn a dual layer image (maybe on a machine with a SIL3112? Dunno how tolerant of Shenanigans, like, Toast is)
Well, that I’m not sure of (SCSI DVD support on System 7 68k). I imagine you need an Apple SCSI drive for best results.
I'm aware I'm the one who created the interest in optical and magneto optical technologies, talking about how the discs are the best possible archival technologies and the drives have proven themselves to be among the most reliable removable media technology formats for the '80s, '90s, and 2000s. I apologize for advocating for this in incomplete form.
I've since learned/remembered a few other things and whole MO is still the best available technology for the era, and the discs themselves will last forever, I think the drives may not:
The inevitability of time comes for all technologies. Did you ever have a playstation 2? I did and a couple years into having the thing, the laser for one of the disc types it supported suddenly went out, leaving us, if I remember correctly, able to play music and PS1 games but not PS2 games or watch DVDs with it.
As far as I know, the same is true of all optical technologies, even into the blu-ray era companies have been publishing press releases about working on the laser longevity problem. In minidiscs, you even see new-era machines from 2001-2005 that look absolutely pristine but have dead lasers, likely because despite their looks they have a lot of miles on 'em.
I don't know the underlying details of why, the best guess I have and that I've seen anyone else have is a combination of usage hours, age, and luck. Japanese minidisc machines will typically have been spinning and reading for hours a day for years on end whereas MO may have, ultimately, seen lighter duty since they can wait until it's time to do an actual r/w to light up the laser.
If SCSI DVD drives were hypothetically bootable on system 7 and/or system 7 had a UDF driver or we could make HFS/HFS+ formatted DVDs -- we'd still need to balance between DVD and MO in terms of what type of longevity we're looking for. The same is true of CD-ROMs and CD-ROMs have the advantage of that there are a lot more of 'em hanging around.
Once you author a DVD (or a CD) for a classic mac, you can back it up using dd or an ISO program on a modern computer and then re-burn it. Modern CD/DVD burners, parts, and discs are still being made.
Nobody is making maintenance parts for MO drives anymore. Ultimately -- as far as I know they're also not making maintenance parts for old SCSI DVD drives, so I don't know if that's actually a better solution.
So, changing course now may not be worthwhile since SCSI DVD drives will be nearly as uncommon as MO hardware and lots of the SCSI DVD equipment is out of stuff like mips/sparc/alpha/power workstations and servers
I suspect that we're not too far off from the most viable solution for bring-up on SCSI-era 68k/PPC Macs is to use modern SCSI replacer of some stripe. Several of them now do CDROM and hard disk emulation, so buying one to run externally as a bring-up tool in addition to internal ones is reasonable.
The nice thing there is with these SCSI replacers, can go right up to the maximum volume limits of these systems -- 4-gigs for '030s and 2TB for '040/PPCss running 7.6.1 or better. There's SCSI<>SATA Bridges for optical drives but I don't know if we've had a chance to try these with Macs. Maybe @Unknown_K has one of them?
In the mean-time, I think we should probably enjoy MO for what it is -- a fun aesthetic vintage technology with an unfortunate expiration date. (The discs themselves will almost certainly last until the HDOTU though.)
Secondarily: How much is there in terms of utilities and stuff anyway? Most of my OS 9 installs fit within ~4-5 gigs in terms of installed OS and all the software I use on 'em, let alone utilities and bring-up stuff.
