Using a Zip 100 drive with a compact Mac
Good news! I got a Mac Plus today, and the Zip 100 drive works great with it. I didn't do anything differently than I had before, so I have to conclude that the SCSI hardware in both the other systems I tried is broken. I strongly suspected there was something wrong with the SCSI on the SE/30, since it's internal HD had disappeared a few days earlier. And I'm not too surprised that the Brainstorm SCSI add-on for the Mac 512K is weirdly different enough for it to not work either.
After booting from a floppy with the Iomega 4.2 driver, the Plus immediately recognized and mounted a Zip disk I inserted. The disk was already Mac formatted, but I think it had a driver newer than 4.2, because if I attempted to boot from from the Zip I got a black screen and weird speaker buzzing! It worked OK when inserted after booting, though.
I first tried to follow the Lido 7.56 format instructions at http://www.vintagemacworld.com/pluszip.html, but the process didn't unfold the way it's described on that page. I was never prompted for anything about blind writes or ejecting removable media-- it just formatted without asking any questions. Attempting to boot from the Lido-formatted disk just showed the floppy with the question mark, like the Mac didn't recognize the disk.
I then tried the Iomega 4.2 driver method described at http://www.jagshouse.com/zipMacPlus.html. Briefly, you just boot from a floppy that contains the 4.2 driver, then insert the Zip disk, erase it using Finder, and finally copy your system folder to it. That worked, and now I can boot from the Zip drive.
I wish the Lido method had worked, however, because there's an evil "feature" lurking in the Iomega driver. The problem is described in both of the Plus Zip pages that I mentioned. If you boot up another Mac that's running Iomega driver 5.x or newer, and then insert your 4.2-formatted Zip disk, it will silently upgrade the driver on the Zip disk to 5.x. If you then bring that Zip disk back to the Plus, it won't boot anymore-- you'll get a crash on boot. I think it will still work if you insert the Zip after booting from a floppy, but the ability to boot a Plus from that Zip is gone until you reformat it. The Lido driver doesn't have this problem. With the Iomega 4.2 driver, you'll be fine as long as you only use the Zip on your Plus, or are careful to only share it among Macs that also have the 4.2 driver, but it's something I'd rather not have to worry about.
I'm not sure what your particular problem is with respect to using it on other Macs. The current OS X drivers do not do the update, and I mainly use the ZIP drive between my vintage compacts and OS X Macs. If you are using it on other vintage Macs, just make sure that the ZIP Driver installed on all of those Macs is 4.2 - I've yet to see a Mac that didn't work just fine with the 4.2 driver. That's how I've set up all of my Macs, so no accidental updates. If you need the ZIP Tools and extension, then make sure you have the 4.2 version. I've been meaning to make it available for download for some time now, but haven't. Not even sure where it is at the moment. But I found it with a short Google search.
Now I suppose if you are using it with random vintage Macs you encounter in the world, then yes, you'll run into problems. However, if you reboot the Mac with the ZIP extension temporally disabled, I believe this will prevent the update. It's been a while since I did this, but it may be the work around. Also, you can lock the ZIP disk so changes cannot be made. I seem to recall using this method back in the day, so if I stuck it into a system that had a newer driver I would be OK. Once inserted you can copy a 4.2 driver from your ZIP disk into the extensions folder and reboot, temporarily disabling the newer driver on that particular Mac. Always keep a copy of 4.2 disk tools and driver on the disk for just such situations. Or, as Trash points out, as long as you are rebooting, as long as the zip drive is connected, all you have to do is bring up extensions manager and temporarily disable the ZIP driver, which allows the drive to boot off it's own driver without fear of being updated by whatever is installed on the computer. And of course if there's no ZIP driver on a particular Mac, you'll have to reboot anyway to bring up the disk, or even plug in a ZIP drive.
You can also use ANY system on a Zip disk, back to 1.1, as well as format the disk MFS. Check out this tutorial - http://www.mac128.com/zip
It's still OFF LINE for me, while every other site on the planet that I've checked is ON LINE. (Google's cache of the site still works, of course.)
Not necessarily, yesterday Mac128.com was down for me. And today it's up. I think it may have something to do with certain DNS servers not always resolving the IP.
Sorry, I should have been more informative - the website I linked above is a quick way to test if it's a local problem (your local machine, local DNS cache or your DNS server) or if it's a problem with the site's server or DNS. The "its just you" is the tool's verbiage, not mine.
Augh!!
The problem I was afraid of has now happened. I mounted the Zip disk on my Power Mac 8500, it silently updated the Iomega drive on the Zip media, and now it no longer functions as a boot disk for the Mac Plus.
You may use any disk formatting tool on the Plus to format the ZIP media (like FWB Harddisk Toolkit or a hacked Disk Utility). Backup the contents of the ZIP media in advance, please. Afterwards it might withstand attempts of silent updates of the Iomega Software. It also should work without an Iomega driver in the system folder.
Since the Zip still mounts in the Plus, but doesn't boot, I was able to back-up its contents to a hard disk and then reformat it.
If I use Lido 7.56 to format and initialize the Zip, then copy a system folder to it, I get a flashing question mark when I try to boot from it. Which is exactly the same behavior I'm getting from two other external hard drives on this computer (see my other thread about drives that the Plus can mount, but not boot). So that's weird.
If I boot from a disk containing the Iomega 4.2 driver, then use the Finder's "Erase Disk" command to erase the Zip, then copy a system folder to it, then I can boot from the Zip. So I'm back in business there.
FWIW, I can't use the hacked Disk Utility, since it requires system 7 and I'm running system 6.
I was unable to find a working copy of FWB Harddisk Toolkit. The one I got from Macintosh Garden contains two programs- one seems to be some kind of utility for locking/unlocking files and volumes, and the other tells me I need a PPC Mac to run it.
