Upgrade SE to superdrive; which parts has to be swapped?
I do know that the hardware is different between a SE and a SE with the superdrive, but I can't find exactly what has to be chaged.
At the moment I have 3 machines sitting on my bench, and I am making a good one out of the 3 parts :) One of them has a Superdrive; the logic board is not working, so I can eventually take parts out of it and transfer them on the vanilla working SE, to use a superdrive, right?
Which parts should I get, beside the drive?
  • ROM HIGH
  • ROM LOW
  • IWM
  • Floppy drive
That's it. Be careful not to bend the pins when removing the chips and put them back the way they used to be: notch towards the front of the machine, opposite to the ports! Otherwise it will fry both the ROMS and the board.
then again , if you wanted to do that , you could put the motherboard in a se/30 (ive done this to my se/30) it  will work fine if you have extra se/30s
Well, if I had an SE/30, I would use that :) They are more expensive than the regular SE, and from what I read, more prone to caps leaking, so I am OK with a slower model; but the 1.44 floppy is much needed to get data in and out the machine.
