Hi guys and gals
My 128k AB doesn't work correctly. Screen is completely dark (crt tested ok), but it bongs and it apparently boots ok from the floppy drive.
Since bibilit and I are practically neighbours (we live 14 miles apart), he's usually the one that fixes most of my stuff. Thanks again btw for fixing my SE/30's LB, AB, FDD as well as the Plus AB!
Last week end he tried to fix that board. He reflowed all the known-to-break solder joints and replaced all three filter caps that were about to burst. But it didn't work.
I suspected the flyback, but then he told me he had a Plus with the same problem and that he tried replacing its flyback with a know good one among with other parts with no luck.
C1 & C2 get abnormally hot 10 seconds or so after switch on.
So, do you have any idea what might be causing that problem?
