I have a Umax J700 and its power supply (Seasonic 250gpx) seems to be dying. Does anyone know about these?
- Are they easily replaced with newer PSUs? If so, how do I determine which one is best?
- It has a 12-pin connector whereas later PSUs have 24. Can a newer PSU be used with an adapter?
- Is it mostly capacitors dying that kills PSUs and those could be replaced to revive it instead of trying to replace it?
Appreciate the help.
