So I've got two original SE motherboards: one from the SE I took apart to build my test stand, the other from my own SE dual 800k. Both exhibit the same issue: incredibly slow sees and access time via floppy drives. Even startup is incredibly slow. The head moves back and forth maybe once every 30 seconds or longer. What is usually a thirty second startup from a floppy could take 5+ minutes. The drives work perfectly fine: the drives from each machine work perfectly inside another machine, and other machine's drives do not affect the problem with the affected logic boards. It's almost as if they are stuck in slow motion, as if there is interference of some kind. On my SE, I thought that possibly there was interference from bad filters, so I replaced them...to no avail. I have no idea how to proceed to tease out what is going on. Has anyone else had this sort of issue before? If so, any successful fix?
