Another bit of data for the mystery. I took the panel apart to see if I could find any physical defects. After removing the backlight, diffuser, etc... I was able to see through the panel and it was perfectly clear. I put it back together, put it in my powerbook and it looked great. After about 30 minutes the tunnel vision effect started to appear. I left it on for an hour after that to see how far it would progress. I the took the panel apart again and tried to see what it looked like now and I discovered something. Not only was the darkness at the corners and around the edges present, but the actual menu bar (which was extensively involved after an hour of darkening) was still present! I know it was the menu bar because I could easily read "File", "Special", Finder, etc... when I looked through the LCD. Somehow, whatever this is, can actually cause a complex image to be retained on the screen after power has been cut. So, does anyone know what could case a polarity inversion and allow a image to persist on a TFT-LCD after power is removed but eventually degrade to the point where the LCD looks completely normal, but have it come back again with use?
