transceiver networking
Hi guys, sorry for more networking questions, I’m using a centrecom AUI to 10Base-T Ethernet Transceiver, is that compatible with my se/30 NIC card as I’ve just read apple used Aaui protocol? Do i need a crossover cable instead of standard cat5? Any suggestions to get my mac online would be appreciated
neal
I wish it just had a RJ45 standard type :(  as I’ve never managed to get my se/30 online/networked. All my other macs just work.
Honestly, at this point, I would buy a Netgear EN104TP hub. Should run you about $10-$20. I KNOW THIS WORKS, as thats what I used with mine, and there will be no guessing game. If you cannot get it working with that, then you can rule out the hub.
I don't think that will work with the hardware he has.  Despite the title of the listing, that is not AUI, it is AAUI. They are not mutually compatible.
AAUI is a dense 14 pin D type connector:
AUI is a standard size 15 pin DB-15 type connector:
Introducing more thinnet shouldnt' be necessary, although it might be fun.
I'd say, for the moment being, follow the advice of adding a dumb hub.'
Before you do that though, what do the lights on the adapter and your switch look like? Do they recognize each other and are there link lights? If so, a hub probably isn't needed, and something is misconfigured or not enabled in the software.
I have the 15 pin bottom one which looks like AUI connector then?
I have a 10base switch I brought only a few weeks ago as my old one wasn’t auto switching, I’ve had the transceiver for some time the one below.  I’m just not sure if I’m doing anything wrong?
now for all i know the shiva may not even work as I’ve never seen it working it was in the se/30 when I brought it so have no idea although the lights on the transceiver come on to say there’s a connection but thats it, same with the transceiver I don’t know if that works either but again lights come on so I presume it does, as for cables I’m just using standard cat5. Settings are the same as my PowerPc in TCP/IP so I’m stumped
Definitely worth a try Jonny although i think trying to find out the problem area first rather than buying more bits is the way forward at the moment. I mean I presume i can do something like a ping test to check the nic works? then check the transceiver as i know nothing about them, followed by cable and router. The router works fine on the PowerPc and imac g3. Should i be using open transport? Should i assign a static IP address etc etc... i just don’t know where to start really
Easy thing to do to see if your SE is at least showing up is to turn on the SE, set up whatever TCP program you have to the best of your knowledge, connect all your cables, etc (Not in that order. You know what to do in what order). Once its all on and connected, download a network viewer app on your phone or computer, one that scans the network (LANscan type thing), and see if your SE shows up. if it does, then you are good to go, and its a software thing. If not, then it is probably hardware.
Theres a 90% chance it will not show up if you dont have a dumb hub. You need a dumb hub first. And thats mostly with all of the older macs.
Use a loopback to test the card and the transceiver. If that fails, you know you have a hardware problem with the card or the transceiver. (the chance that it is the transceiver is very low, they are very simple devices)
Loopback Paralel.  Loop what where?
It's something you can attach after the transceiver that will allow you to test the hardware in your machine to see if its functional. It will help give you a better idea of where the problem might be.
It's a little Ethernet plug:
144890804_RJ4520Loopback20Plug20(Ethernet)20with20Black20Boot.jpg.7f6e51928d852c159426d649ed596f55.jpg
It looks like an ethernet plug that has its cable chopped off, but its supposed to be just a blind end. The loopback plug will allow you to test your system hardware
