Hello all,
I installed a micromac ThunderCachePro on my CC and nothing really seems to be faster.
I bought this card back in 1997 and decided to give it one more try.
When the CC boots it recognizes the MM TCP V1.0 Extension also the card because it beeps only once. 32-bit addressing is on. Memory on the CC is max (10 Meg). Everything is setup according to the requisites, but Speedometer 3.06 is not given a much higher rate for the CC.
CC is running System 7.5.5
Also, the extra memory installed on the card is not showing on the "about this macintosh", only the 10 Meg shows up.
So, I wonder if anybody has this one or a similar card running. The support email at www.micromac.com gives me "delivery failed".
This forum is my only hope.
Many thanks,
Marcio Pocciotti
Many thanks,
Marcio Pocciotti
