So, what the title says. I have a so-so working Color Classic, that has been upgraded in a lot of ways. It uses a 575 board, with 64MB RAM, an Apple CS1 network card, full 040, Defor's ColorFusion LC PDS video card, BlueSCSI v2, and floppy gear upgrade.
The Analog board was modded to display 640x480, VGA mod, and completely recapped/replaced some components, like the ultra hot Zeners, RIFA cap, etc - the works.
So, this beauty starts giving me occasional video problems - the image would be unstable, then it would go back being excellent etc. I other threads, and replies I got, it seems the flyback is at fault. It's the only part that is irreplaceable. The frigging trinitron tube this machine employs was built for two specific uses: as a Medical machine monitor, and color monitor for television studios cameras. Therefore NO replacements can be found. I could not find a used Analog Board, I've kept the WTB post here for a long time and been on the lookout for weeks and no joy - but i found a second complete Color Classic.
So I got this crazy idea. Rebuild the logic board hoping that the second CC has a good FBT, and use it to build a fully stock and collector grade Color Classic, with original LB, tube resolution of 512x348, etc etc.
And build a second one with all the bells and whistles of the Mystic upgrade BUT with a completely redesigned "analog board", using a standard ATX/SFX PSU with soft power, MUCH better audio, and a 8.4" LCD display.
The new AB would be a PCB housing the original connector for the CC harness, routing the power rails from the PSU, placing the original AC socket and power switch at the correct spot on the rear bucket and circuits on it would include a stereo audio amp, RGB and SYNC signal routing to an internal VGA connector (or something like that), sense line setting for the two resolutions that the VGA mod originally devised for the Takky/Mystic provided (640x480 60hz and 800x600 56hz).
Incidentally, I got my hands on a "NIB" GVision K08AS 8.4" monitor/Industrial LCD that IS exactly 8.4" with VGA analog input. Already got it and I am happy to say that it works perfectly with the 68K macs I have (LC475, Quadra 700), at both resolutions, 640x480 and the native 800x600 that are relevant to the CC. Nice thing, I tested it at the oddball 800x600 @56hz, and it works fantastically, although reporting 60hz... here is the Ebay BIN for 29 euro: https://www.ebay.it/itm/312807856587 (no connection to the seller).
As soon as I receive the "parts" CC, I will sell from it a few things at Forum friendly prices, just to recoup some funds to fuel my project - namely the CRT, LB, floppy, and what else I will not be using for this build.
I intend to design in Diptrace the full PCB with the same footprint as the original AB, and if everything works, I will post the Gerbers and BOM - I will also have at least three boards to give out as i will only need the one to place in my CC. This is the intention, and I will update as soon as I get some materials and info.
