Hello,
In school two days ago, I noticed something unexpected on my computing teacher's desk. Closer inspection revealed it to be an old Rodime hard drive. I spoke to my teacher and he agreed I could borrow the drive to see if it worked, and if there was any data on it. I took it back home, but before I attached it to a Mac (I'm fairly certain it is from a Mac - the school used Macs almost exclusively throughout the 1990s) I thought I would check a few things.
1.) There are two wires, a red and a black, on the back of the HDD that appear to have been cut. I cannot find any connection terminals where they would connect to, and I am not sure what they are for. Does anyone know what the wires are used for and if it is safe to power on the hard drive with them cut / disconnected?
2.) Is there any procedures that should be carried out before the drive is powered on? Should I warm it to a certain temperature, power it on but leave the data cable disconnected, etc...
3.) How possible is it that the drive could cause damage to the Mac I am using to test the drive, and if there is a possibility is there any way that it could be reduced (e.g: by powering the drive off a completely separate PSU). I only spoke to the computing teacher briefly about the drive, but he did mention that it had been dropped several times! I am interested to see what is on the drive, but I don't want to break any of my Macs in the process.
I have attached photos of the drive, the underside of the drive, and a close-up of the two wires that have been cut / disconnected, if this helps.
Andrew
Andrew
