System Picker
If you use the System Picker program for 68k Macs to choose a system to boot with and then click the restart button, the system on reboot briefly loads a system and then starts over and does another. Rinse repeat with more until it settles on the system that was chosen. Why is that? Is there a way to prevent that? Would I need to eliminate the other system folders?
Some good info here: seems a combination of setting PRAM and then "blessing" the correct system
