ive read that running a CPU up and around 800 or so mhz on the B&W towers will kick the bus back to 66mhz. due to this im considering a 500 or so mhz cpu upgrade.
the question i have: can i take the zif G3 board and solder any of the CPGA 360 G4 chips to it? or do i need a G4 zif card to start with?
the chips in looking at: 7410 7400 7445? im having a hard time finding data sheets for these old CPU's, not sure if they are all interchangeable.
should just need resistor changes to reduce voltage from G3 to G4, right? then firmware flash on the G3 box itself?
i would love to have a 550 or 600mhz so i was thinking of finding a 500mhz CPU (they are on ebay for 9.00 raw) and jumper over clocking it to 550 or so.
