Sonnet G3/250 for a PM6100/66
Hiya all,
Sometime ago I bought a Sonnet G3 from Strimkind on here, but I don't have the actual software to make it work. On these forums I found Sonnet Crescendo EnablerV31. But it doesn't work, it freezes upon loading the extension. The Powermac works fine with extensions off. I also googled it and sadly it seems that I need an older version, but the Sonnet homepage turns up blank(all accelerator drivers seem to have been removed :(0 .Anybody know where I can get older drivers?
Also can I use these cards with System 7.6.1 or do I need to use 8 or9?
I can't seem to find the posts on google which talked about the versions of drivers. But If you have any older versions I would be aces if you could upload them so I can check them out.
Btw do you know if you can use 7.6.1 or do I really need to use 8 or 9.
Thnaks so much already!
