SOLVED!  $22.38 mSATA in G4 Mini
jimjimx
[SIZE=11pt]I looked at my options, and bought a 128GB mSATA drive, and ATA adapter, for a combined total + shipping = $22.38, and replaced the 80GB spinning platters in an A1103 1.5Ghz, 1GB, and now 120GB storage.[/SIZE]
[SIZE=11pt]I split the drive into 2 partitions an put OS 9 and 10 on there.[/SIZE]
[SIZE=11pt]I think I’ll take OS 10 off, and use OS 9 only.[/SIZE]
[SIZE=11pt]I’m not sure why I did any of this, so if you have any ideas, let me know.[/SIZE]
[SIZE=11pt]Here are the results.[/SIZE]
[SIZE=11pt]                         HDD                            SSD[/SIZE]
[SIZE=11pt]Weight             Heavier                       Lighter[/SIZE]
[SIZE=11pt]Size                 Bigger                         Smaller[/SIZE]
[SIZE=11pt]Noise               Louder                        Quieter[/SIZE]
[SIZE=11pt]       OS 9.2.2   (Native, not “Classic”, Ver. 8 from [/SIZE][SIZE=11pt]MacOS9lives.com[/SIZE])
[SIZE=11pt]Boot time.       54.7                              41.8 sec.[/SIZE]
[SIZE=11pt]Benchmark      Not tested[/SIZE]
[SIZE=11pt]       OS 10.4[/SIZE]
[SIZE=11pt]Boot time                                             42.7 sec[/SIZE]
Do you have links to where you bought these? The prices of SSDs keep falling -$22 is much more reasonable than $200!
Thanks!
eBay.
The adapters are under $3.50 and the mSata SSD depends on on size and quality.
Bigger is more, pre-owned is cheaper.....
I would also stay away from the TLC, and stick to the MLC.
If I did it again, here’s what I’d get..
https://www.ebay.com/itm/mSATA-SSD-to-44-Pin-IDE-Converter-Adapter-as-2-5-Inch-IDE-HDD-5-Volt-For-Laptop/263766651638?epid=1331356730&hash=item3d69b7b2f6:g:GhoAAOSw5MdbKKhM
https://www.ebay.com/itm/V800-MSATA-Solid-State-Drive-1-8-SATA-3-SSD-Hard-Drive-MLC-Particle-120GB/133035698902?hash=item1ef98baad6:g:eYYAAOSwOpFcxWI4
Thanks!
Newegg has some MSATA drives on sale for $15.99 at the moment.  I think the manufacturer is Dogfish.  I know nothing about that company.
Looking again, the $15.99 ones are only 32GB.  There's a 64GB for $19.   128GB is just shy of $30.
If ya have a lot of computers you want to do it to, here a lot of 128GB mSATA drives.
https://www.ebay.com/itm/Lot-of-5-128GB-mSATA-Drive-Hard-Solid-State-Drive-SSD-Laptop-Storage/183687191455?_trkparms=aid%3D222007%26algo%3DSIM.MBE%26ao%3D1%26asc%3D20190212142712%26meid%3Df80384f843924708a512fbc58aeb27b1%26pid%3D100037%26rk%3D2%26rkt%3D12%26sd%3D233213700669%26itm%3D183687191455&_trksid=p2047675.c100037.m2107
The mSATA 44 pin adapters are all over eBay cheap, but I did wait 4 weeks for the adapter to arrive from China....
let it us know how it works out for you.
