I'm about to retire my S900 based frankenstein and move to a G4 MDD as my main machine. But there are still a few games I like to play which really work best in 7.6.1. I'm willing to keep an extra machine around to play them, but I'd like for it to be physically small. If there was a Mini which would run 7.6.1 that would be perfect, alas.
So, any thoughts on what is (or can be) smallest? I'm happy to do case cramming: i.e. take the guts out of a larger machine and cram them into a smaller case.
I was looking at the Power Wave from Power Computing because it has the PCI slots turned horizontal on a daughter card, which makes the logic board smaller. However, the PCI riser card for the thing is *tall*. Those crazy PCC engineers put the PCI master slot next to the CPU slot and then they had to make the PCI riser card really tall to avoid interfering with the CPU card. Anyone know with the PowerCenter/Tower/Center Pro are the same way?
I was hoping I could cram it into this case:
http://www.interloper.com/products/product-details.php?productid=51000029&cat=51#
But the funny riser on the Power Wave doesn't work with the NLX standard. Grrr.
I don't suppose anyone has ever made 7.6.1 run on a Beige G3? That would be ideal. Small ATX form factor. Uses ZIF CPUs. Etc.
Right now I'm investigating how compact a Umax C500/C600 can be. The PCC PowerBase probably also bears looking into, but in most cases, to get the detailed logic board physical information I need, I end up needing to actually buy a used machine (or at least logic board). That way lies madness.
