Shiva FastPath 5 - mainboard voltage
Hi Guys,
I have a Shiva FastPath 5 that I bought cheap on eBay a while ago from a seller in the US and imported it to Europe. I almost connected it to try it out, when I read the sticker on the back saying 120V 50/60 Hz. Disaster avoided... but also no vintage mac TCP/IP :(
I opened it up and looked at the power connections: it is just a standard transformer that is connected to the power input, which then connects the (presumed) DC to the logic board. (http://www.walshcomptech.com/fastpath5/fp4pics/ This is a version 4, but it looks almost the same). It looks like there is no internal regulator for multi-voltage, just the transformer, so If I plug it in here in Europe, it will probably just fry the board.
Does anyone know what voltage the logic board needs in these devices? I could then power it with an alternative power source?
Thank you in advance!
Where is the power connector on that logicboard?
It is going to need at least 5V for the logic and something 9-12V-ish for the BNC transceiver part.
Hi,
Should have taken my own pictures from the start - please find them attached now of the PS and the board.
It is only 2 wires going from the power supply to the board. So I am guessing that there is a single input voltage, that gets broken down by the boards itself if needed.
Jealous you have the RJ-45 module. I have to use an AUI adapter on mine - takes up more room on the shelf :-)
I bet that transformer's primary can be reconfigured to run on 230 volts.  I would take some pictures of that.  I *might* be able to tell you how to change it.
Yes, it is quite a convenience, IF I would have the power to run it :) . I would not mind the extra dongle really, as it would live in my network cupboard next to a Ethernet router.
I have the same one!
I just use a converter. See f.i. this page.
https://www.amazon.com/slp/convert-220v-to-110v/eey2uug67aq74rn
I have tried to find something that would work, that would convert the voltage but still retain the euro-plug (as I do not have any US power cable, as all adapters have the US plug on the other side). But no luck. That is why I started this topic to see if someone else had any other way. If all else fails, I will get an adapter and get a US power cable - or perform surgery on the adapter to change the outlet on it.
Wow, that would be really nice! I will take closer pictures of it tonight. Any special parts you need more detailed pictures on?
Thank you all for your answers so far!
The transformer may well have the numbers of turns on each winding written on a label on it?  If it does, we can probably work it out from there...
 Hi guys, sorry for being away for some time. I have now taken more pictures of the transformer and the jumper +cables. Hopefully you can make something out ::)  ?
That jumper appears to wire two primaries together in parallel for 120v operation.  I THINK that jumper should be able to be modified to put the primaries in series, which should output the correct voltage.
Thank you for the help - and for the good suggestion! :)
I do not feel comfortable rewiring it on my own, so I might just do what mactjaap says and get a step down converter, and change the output socket of that to the euro-plug to use a euro-powerlead.
Think that will be the easiest solution.
Again, thanks all for the points!
Makes you wonder why they didn't put in a 115/230VAC switch to begin with. Rewiring the jumper wouldn't be hard assuming the black wires are all on the "hot" side of the transformers and the brown wires are "neutral".
Wow, thanks for that! :)
I now have it up and running with a PS outputting 15VAC and connected to the mainboard directly.
Thank you everyone for the help!
That harness inside the unit does allow one to reconfigure the unit to work with 230VAC. Looks like they came with a double tapped transformer. The older Kinetics Fastpath 4 also came with a 115/230VAC switchable power supply with a jumper wire too.
Very easy. The big transformer just steps down line voltage to ~15VAC. The AC to DC conversion is done on the Fastpath 5's main circuit board. I haven't taken the Fastpath 4 apart enough to see how it works, but rewiring it looks to be one wire.
EDIT: Yep, Fastpath 4 has a "230V" terminal on the power supply. Looks like you can just move the wire from the 115V terminal to 230V and be set. Unlike the Fastpath 5, the Fastpath 4 has a full power supply board and directly provides DC to the main logic board. Its an off-the-shelf Delta SMP-40BP. Looks like a Scantron machine used the very same unit!
