Sheepshaver to SD
So I create a virtual drive and set up a machine config. I install an OS. I use TransMac to restore the image to the SD card in a USB reader. Then I put the card into an SD to IDE adapter and into a 5300c. What will go wrong there? I got error 10 last time.
Make sure the SD card is formatted with at least Mac OS 9 drivers.
Other than that, I have no idea.
c
If you are formatting in OSX, go to Partition first, then click on Options. Select Apple Partition Map. Then select Mac format (not Journaled or Extended). Then format with OS 9 drivers.
From there you should be able to copy a system folder to it.
(I'm on Sheepshaver but that will only work (the OS Formatting) on 10.4 or below. Possibly 10.5 but I think they dropped Mac Standard/HFS support after 10.4.)
10.5 still has it. It was 10.6 that dropped write-support for HFS Standard.
I don't know if 10.5 will install Mac OS 9 drivers, however. Better stick with 10.4 for now.
c
