SE w/ Superview
Well what do I do with this card?
I assume its monochrome because it has a 9 pin D.
It doesn't kill the SCSI drive like the power book "superview" is said to, does it?
Is it worth trying to find a monitor? Vertical one?
Thanks!
Here is the monitor spec's.
' target='_blank' rel='noopener'>
picture of monitor
http://www.flickr.com/photos/48978576@N08/8666745044/in/photostream
I think this is a ttl monitor. The monitor looks like it was made by moniterm it was called a macviking.
It was a two page monitor.
You will also need the driver software for this card.
