Hi all, I'm currently trying to fix up an SE/30, and could do with some help diagnosing the problem.
This machine came to me with simasimac, and a burst Maxell PRAM battery, but after a thorough clean and recap, and a couple of repaired traces, I put the board back in the SE/30, powered it on, and got... nothing. No bong, no image, no fan, no disk activity.
The behaviour is exactly the same whether the logic board is connected or not, and therein lies my question - is that normal?
I cleaned, and recapped the power supply although admittedly, I made no effort to replace the largest cap (I'd heard they're much less likely to fail, and couldn't find a replacement). Same result. Then, I re-soldered a few joints on the analogue board that looked slightly suspicious under the microscope. No change.
Am I on a wild-goose chase here, and the problem is still the logic board, or is there also something wrong with the PSU/Analogue board?
What should happen when the SE or SE/30 is powered on without a logic board?
I haven't been able to find any definitive answer on this, although I feel like there's sometimes an implication that the fan would run, even without the logic board.
Any information, or anecdotes would be welcome.
