Does anyone know of a .stl or pre-made expansion panel that has slots for both VGA and SD card? I have one for my bluescsi v2 to mount it to the bay, but it does not fit with both of the PDS cards mounted. The bracket cannot be modified since the physical bluescsi would also be in the way.
I plan to hot glue this one into the plate I have, that already has a VGA slot in it: https://www.adafruit.com/product/3687
