OK, so I recently recapped my SE/30 mainboard and it went smoothly, and it resolved a weak sound issue. Little guy worked just fine. Great, I thought, I'll get ahead of the curve and recap my (Astec) PSU and analog board. That goes smoothly as well, and I resoldered a few grey-looking connectors on the ab while I was at it. Reassemble, power on... thin vertical simasimac and no chime.
Weird, but OK, time for some obvious checks:
- checked voltages, all rock solid coming off the ab, and the usual checks on the mb
- double checked the ROM SIM and make sure it's clean and seated. A few greyish pads toward one end, clean them up, do a iso clean of the slot, dry it out, test some continuities, seems ok, reassemble, no change
- check continuities on some IC's I reflowed (UE8 for instance), all good
There are other paths I can go down, but I have a question: what is the likelihood that the PSU or ab recap could be the cause of this? It's the only thing that changed from a working SE/30 to now. I'm going to wash the mb one more time to be sure, but it WAS working before now, so I'm unsure. I know coincidences are more common that I'd like, but it's not the first place to be looking... so... thoughts?
The only possibly weird thing I'm noticing is a series of about 8 very faint clicks coming from either the ab or psu a few seconds after power on... I'm not sure if that's normal or not.
