SE/30 - Front casing plastic fix?
mdent23
Hello all,
I wanted to hear your thoughts on this;
I recently acquired a recapped SE/30 (which as of this past weekend is now using a CF card for solid state storage and super-fast startup!)
The machine is beautiful, but what has proven a mixed blessing is the damage to the plastic of the front casing that occurred during shipping (I say this because I ended up getting the machine for free via UPS shipping insurance due to the damage and an unseated ROM SIMM which caused SimasiMac)
To cut to the chase: Has anyone had any experience repaired cracked or broken off plastic on these compact macs?
My plan is to reattach a piece, fill in the cracks (pictures below) with some kind of material), then sand it down so it is flush with the rest of the casing.
Here's a link for a two-step plastic I found, if you have any suggestions or alternative solutions, I'm all ears.
http://www.plast-aid.com/
// mdent23
Lemme know how it turns out.  I have a bezel you can have for free + shipping.  Won't be pristine, but it won't be cracked.
olePigeon that would be amazing!! The seller treated the plastic to remove yellowing and gave me the recipe so I should have no problem matching it!
Just let me know how I should send my info and we can talk details.
Thank you
-mdent23
Just PM me your address and I'll get a shipping quote for you.  May or may not be worth it.  I suspect around $15 or so.  It might fit in a medium flat rate box.
there is a trick about ABS  (if you can find a plastic item of the same colour) mixing acetone and tiny bits of plastic will produce a bonding material.
Very cool, though thanks to olePigeon I am expecting a new front bezel now which I will chemically treat to remove any yellowing and get the color match to the back rear case as close as possible.
Will keep you all posted with results!
// mdent23
PM'd you my address info, olePigeon; looking forward to receiving the bezel! Thanks again :D
//mdent23
Note that the plastic you dissolve in the acetone has to also be ABS.
... I will chemically treat to remove any yellowing ...
I did some retrobrighing in my Classic case and i must say it wasnt easy. It took about four half-days to get to a satisfactory result.
I tried both wrapped and unwrapped, applied with a brush or just using gloves...
And the best results came while spreading only with gloves, unwrapped.
Using a brush tends to create micro grooves that will create micro shadows and will result in an uneven treatment.
Using a glove will get you a better spread. But since it will dry-out more quickly, you'll have to reapply more often
