Thanks for the Raspberry Pi info! What model device do you have, just out of curiosity?
The AppleTalk control panel won't affect your ethernet connection. The router side is important because many modern routers won't step down the speed of the port. In the case of my ISP, for instance, they block the ability to change the port speed because they don't provide support for equipment old enough to require 10mbps.
Log in to your router — probably via 192.168.0.1 or 192.168.1.1 — and check out its control panel to see if you can change the port speed. If it's giving the MacCon gigabit speeds, it just won't work.
Make sure the switch position is right for your model card — it could be different from mine — but I'll bet that's probably the correct spot.
