SCSI2SD Setup Troubles
I am going to guess that conflict catcher is some software.  I will start looking.  Thanks so much for the help!!!
mraroid
I found a older version of conflict catcher 3.0  and down loaded it.  But my copy of Stuffit expander said it would not work on the file.  Stuffit said I needed a copy of Stuffet Deluxe. I found a older copy of Stuffit Deluxe version 5.5 but it looks like it might take a hour or more the un compress the file.
I will check back. I would buy a copy conflict catcher if I knew which version would work on 7.5.6.  It seems like a good tool to have around.
Thanks everyone.
mraroid
… it's a little bit annoying to have to always click cancel or whatever, but it doesn't affect usability.
I wonder if this little AppleScript in the startup folder will click the Cancel button for you. I can't test it but maybe if it doesn't work you can modify it.
tell application "Finder"
-- click button "Cancel" of front window
click button "Cancel" of window 1
end tell
If the line with the double en-dash, which is just a comment, result in an error delete it. It's meant to be a comment only.
If you need a delay before it executes the tell, just enter a line on top like this:
delay 20s
-- 20 second delay
